hd5 bulldozer frame
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Topic: hd5 bulldozer frame
    Posted: 10 Jul 2010 at 8:59pm
anyone have any interest in this? it still has the trans and ring and pinion but no clutches or final drive gears. i have all those saved separately. had a bearing go in the final housing so it needs repair to use. trans has welding on it from previous repair. machine ran and drove when disassembled. anyone need anything you see? let me know and make me an offer. it is heading for the scrap yard as i don't need anything more from it.
Gary(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2010 at 9:46pm
What would you want for the shift lever   Gary Roidt
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 7:03am
do you need just the lever or the shifter assembly? $10.00 plus shipping for just the handle, let me know if you need more. thanks.
mbgirod View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mbgirod Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2010 at 12:21pm
Any chance you still have the shift lever for the HD5G?  I see someone inquired in July.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2010 at 7:13pm
The shifter for both tranys is the same , a small stub shaft that the lever bolts onto. I believe I may have a 5G shift lever around yet.
 The end of the stub shaft is easily rebuilt with a little welding and grinding to new looking and working condition. The cross bushing and the pin that holds shaft to bushing also will need tightening as well as replace the 2 bolts that go into shift tower as they wear inside bushing.
The lever it's self is different in the dozer is not offset much and after 90 deg bend, at stub shaft, comes straight up. On the 5 G it is offset more from 90 deg and bends out to allow leg room and be more compact because of loader framework making area smaller in opperators compartment.
Edited by Coke-in-MN - 27 Nov 2010 at 10:27am
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 5:48am
i do still have it, i do not know it's condition but i will check on it. the frame is still the same as in the picture. have not got the hot wrench to it yet. i will check today and let  you know it's condition.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 10:31am
dadsdozerhd5b : the trany and gears has to be worth putting on the shelf, if it is 2 speed reverse positivly as finding the gears for that is hard.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 4:34pm
i agree about the spare parts but i already have 2 complete trannies on the shelf and this one has had issues in it's life as the case has been welded up. must have exploded at one time. one of the shifter bolts is welded in making it a bugger to get out if it is worth it at all. it is a single reverse as are my other two. i thought at least the 2 speed reverses were in the loaders only but they may have put them in the hd6, i don't know. my dozer has a 2 speed reverse from a loader. if anyone os interested in the whole tranny for parts, i will take a small (scrap price) offer for the entire tranny. it did move and shift correctly when it was disassembled. i kinda figured the 2 speeds were hard to get parts for aas i am always on the lookout for a spare.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2010 at 9:29am
All the other gears are the same just that the ideler for reverse has 2 sets of gear teeth and the slider gear that meshes from mainshaft.  Have a set of gears and shafts from single reverse on shelf also but sold last 2 sp trany I had .
