8010 allis
allis power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis power Quote  Post ReplyReply Direct Link To This Post Topic: 8010 allis
    Posted: 29 Dec 2016 at 7:28pm
 On my 8010 I am  trying to put on a engine bypass oil filter. I Know they used to a sheet showing how to do it.  I am also trying to install water conditioner filter on it. If anyone knows how I would appreciate the help   Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 12:13pm
Save yourself a lot of grief and use good/pre-mixed antifreeze from Cummins or Caterpillar. Coolant filter creates about six more places for a potential leak. Keep it simple....use the right coolant to begin with.
BigBadAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigBadAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 1:26pm
Agree with DrAllis
Heavy Duty coolant come pre-charged with SCA's / DCA's .  You do need to check the nitrite levels on occasion to make sure the concentration is at the recommended level.  If the levels are low, you will have serious cavitation (electrolysis) cylinder lining pitting etc.  The additive prevents the microscopic bubbles that when under pressure implode and actually rip pieces of metal off the liners or block.
The conditioning elements were widely used with the older green coolant that did not have supplemental additives.
Jason
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 2:04pm
If one would just simply CHANGE the coolant every two years, you'd never need to worry about testing it for proper strength.
tornado8070 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tornado8070 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 6:17pm
Do you have text capability? I could send you some pics to help you out?
09’ DT205B, 08’ DT220A, 83' 8070 MFWD, 83’ 8070 85’ 8050 MFWD, 83' 8030, 82' 8010, 85’ 6080 MFWD, 84’ 6080, 79' 7020, 85' M3 RWD, 85' 920 diesel,AC C-50 forklift.
This page was generated in 0.396 seconds.
