wd45 12volt |
Larry B
Orange Level Joined: 11 Sep 2009 Location: charter oak Ia Points: 386 |
Posted: 02 Jul 2010 at 5:32pm |
Bought a wd45 with 12 volt alternator and battery, the coil is supposably from a d17, i know the lights won't work that way but will everything work or should i get the right coil and put a resistor on it?
Chalmersbob
Orange Level Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
change the light bulbs to 12 volt and they will work. The D-17 coil might be a 12 volt coil, in which case you don'y need a resistor. Bob
Brian Jasper co. Ia
Larry, do you have or can you borrow a digital ohm meter? A coil with 3 to 4 ohms resistance on the primary side is what you're after. Before I converted both of my gas tractors to electronic ignition, I was using a coil from a Kohler K series engine. A ballast resistor can be added, but it is best in my opinion to use a coil that doesn't require one. One less thing to break...
