D10 pivot pin bushing
Ranse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Topic: D10 pivot pin bushing
    Posted: 14 Nov 2016 at 7:15pm
I ordered a new pivot pin bushing for my D10 last week from a local Agco dealer here. I can't find this part on line anywhere. Agco said it was available, but when I went to get it I believe it was the wrong part. First of all it was steel, not brass. Then it had an offset about half way down inside it. My front axle assembly has been modified. The pivot pin has been cut out, so I really don't know what it actually looks like. But from what I can tell from looking at diagrams and pictures the pin is smooth (the same diameter all the way). Likewise the bushing should have a smooth hole, one diameter all the way, with on offsets. It should also be brass. I left the bushing at the dealer and they are going to reorder it. They think someone may have pulled the wrong part or something. I was going to use this bushing to determine how big the pin needs to be, because I'm going to have to make it. Does anyone knows what the pin and bushing actually looks like. Any information would be helpful, length, diameter, etc. Thanks
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 7:55pm
that sounds like the right part to me. I rebuilt the front on my D10 III in '85, it had a step back then too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 7:58pm
Front bushing is steel. It goes in the WFE tube. Pivot pin IIRR is a bolt welded to front support plate. I kind of think bushing is stepped inside. If rear pivot and bushing are tight front bushing could be straight thru with less clearance. HTH Tracy
1953CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 1:10am
I used a piece of pipe, cut to length, tack welded same as original and used a new grade 8 bolt. better than new...
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 8:24am
It sounds like I may have been the one wrong here. This makes things more difficult, that means the pin will have to be machined down a little smaller on the end to fit. I also don't understand a steel bushing, steel to steel I thought was never good.
I got another question, does the end of the pivot pin have a support bracket? One diagram I have shows one, although the one in my I&T manual doesn't. If it does, how does it fasten, and were does it fasten to the tractor? Thanks again Ranse.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 1:21pm
On my B I used bushing for three point hitch .From a one to a two and used a hitch pin welded to front of tractor.Hole was worn almost to bottom of axle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 2:55pm
The support was for heavy duty frontend. The pin would not be shouldered for the bushing. I think the original pin was straight. The step bush allowed for wiggle without putting excessive force on torque tube. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 4:11pm
Tracy, are you saying the support was on the heavy duty frontend only? Because mine is the light duty and I didn't think it originally had one. I may add one anyway if I can do it without it looking junky. And the pivot pin should be smooth and fit the small side of the bushing? Thanks for your help, I really wish I had another D10 to look at. Ranse
