7020 power shift noise
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Topic: 7020 power shift noise
    Posted: 31 Oct 2016 at 8:19pm
I've noticed it right since I've had the tractor, the forth power shift in high and low range has a gear noise not loud or rough sounding just can hear it more so than the other speeds. Just curious if I should be splitting it and looking into the planetary gears or is it normal for its age. It has 7522 hours on it. My dad wonders if it was a gear that was used a lot. Any opinions are appreciated, thanks
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 9:14pm
A PS is noisy in all gears. Probably is ok. Take the floor out and drive it around and see if it is worse in that speed.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 9:24pm
New rubber cab mounts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 9:32pm
Are new rubber mounts still available from agco?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 10:54pm
Probaly....how many "arm & legs" you got to spare
