dampers |
ac80701985
Topic: dampersPosted: 26 Jan 2013 at 10:01am |
building an open rpm 426 hot farm. wondering about a damper and what is better fluid or rubber and why. thanks
wi50
Joined: 24 Sep 2010 Location: weegieland Points: 1010 |
Posted: 27 Jan 2013 at 9:18am |
Fluid works better than rubber and is also safer. Typical rubber balancers are made of cast iron. Fluid made with a steel caseing and will survive higher RPM. Also rubber dampers have a tendancy to seperate over time.
Any damper is better than no damper. If you're going to run 3000 RPM than I probably wouldn't spend the money on a fluid damper or the work to customize the crank nose or make some kind of mounting hub to put it on. Maybe someone's got a simple solution and knows of a fluid damper that fits without much work, I'm just not familular with the 426.
Posted: 27 Jan 2013 at 8:05pm |
Crank pulley and fluid dampner from any 7080-7580-8070-4W220-N5-N6-R5-R6 all bolt right onto any 426 crank nose..
bsallis180
Joined: 29 Jul 2013 Location: Pennsylvania Points: 209 |
Posted: 12 Oct 2016 at 9:35am |
digging up some old threads... looking for some fluid dampner info in a 301 application over 3k rpm
Posted: 12 Oct 2016 at 3:34pm |
426 fluid damper (from 7080-7580-8070-4W220-N5-N6) works well on a 301. I think Kenny's pulling parts may make the hub to mount it to. I've seen a model F- combine cast iron pulley machined to accept the 426 fluid damper.
Posted: 12 Oct 2016 at 3:40pm |
You should also use a little longer Gr8 NF bolt, as the crankshaft nose will accommodate that and Loctite the bolt too. I'm thinking the bolt torque I raised to 220-250 ft lbs instead of what spec was.
bsallis180
Posted: 13 Oct 2016 at 10:43am |
does a fluid damper wear out? So you can adapted the 426 on 301, its not the same tapper right?
Posted: 13 Oct 2016 at 11:05am |
The dampener bolts to a HUB. The hub is tapered to fit the nose of the crankshaft. 301 and 426 crank noses are a different size.
Posted: 13 Oct 2016 at 11:07am |
Yes, they wear out. They can leak out the fluid and render them useless. They can also have the fluid solidify over thousands of hrs of use and render them useless too. Any dent to the dampener also makes them no good. I would never buy a used one and expect it to be good.
bsallis180
Posted: 13 Oct 2016 at 6:12pm |
That's what I figured thanks Doc.
2wise4agm
Joined: 19 Aug 2011 Location: Smithton, MO Points: 538 |
Posted: 13 Oct 2016 at 9:04pm |
I have a fluid one made for a dt466 on my 301. It's mounted in kind of a weird way. I machined the front off of a 301 combine pulley and drilled and tapped it to accept the 466 fluid dampener.
