? for soybean growers |
Page 12> |
Author | ||
bakwoodsfarm ![]() Orange Level ![]() Joined: 02 Sep 2010 Location: Woodleaf,NC Points: 511 |
![]() ![]() ![]() ![]() ![]() Posted: 12 Sep 2016 at 10:22am |
I have had a LOT of problems with marestail this year!!!!!!!!!! My question is: I have a field at my house of about 6 acres that I sprayed with gramoxone and atrazine with the intention of planting corn. I did not have enough seed or fertilizer to plant it, SOOOOOOOOO. I used that field to calibrate the drill for beans and liquid fert. That is the ONLY field I have that does not have a single marestail or pigweed in it. I waited 30 days to plant and resprayed with roundup and prefix 30 days later. That is all I have sprayed it and it looks GREAT. Bigger plants, more pods per inch of plant, A LOT LESS WEEDS. Has anyone tried this before, I think I'll try it again next spring.
Sponsored Links | ||
Sandknob ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Oblong, IL Points: 2456 |
Probably worked OK as I'm betting you had a decent amount of rain to activate the atrazine early on. If it doesn't rain to activate it it can sit there and activate later which could cause problems with your beans. This year was not a good year for clean fields. I have a field of roundup ready soy that I just gave up on keeping clean. Actually my old public variety soybeans are cleaner than the RR beans.
Jordan(OH) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Celina, OH Points: 1567 |
You got lucky. Atrazine has a 1 year plant back restriction for beans.
If it does work, provided enough rain, then it sure is cheaper than $17/acre for Envive and still have to spray prefix in 30 days anyway.
ILGLEANER ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Willow Hill,ILL Points: 6448 |
Have done it before. Burn down early with Roundup and atrazine. Then get to late for corn, switch it to beans. It will be clean. I wouldn't recommend it as a practice. But if it rains a lot in between app. and planting l wouldn't worry the least about a pound of atrizine on beans. I see volunteer beans in my corn fields all the time. Never seen that before RR beans.
Best thing for marestail is a disc !!!!!
anybody recommend something more cost effective than Envive?
7060 ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Missouri Points: 1148 |
We have been using envive for 5 years and it was terrible this year. If it wasn't for us switched to liberty beans we wouldn't have been able to control the mares tail and water hemp. I will say that we can't ask for any cleaner fields after spraying once with Liberty though. Like ILGleaner said a disc worked great 4 years ago I disced 3000 acres with a 1435 sunflower ahead of the planter. That's a lot of fuel and work though and the next year it must have woken up water hemp that we never had problems with before.
That is the problem, low prices and high inputs. You just cant afford to disk every spring on every acre. At least I can't. I have started burning down fields with roundup and 2-4D. about half price of gramoxone and kills better. Just would love to figure out the preemerge trick.
wekracer ![]() Orange Level ![]() ![]() Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1590 |
We work all our ground twice. Once deep early spring and then again right before planting. The local elevator had not been as timely as we would have liked for them to be and sometimes it would rain and be two weeks before it got sprayed. So about 4-5 years ago we started spraying residual with saddle tanks and a spray bar behind the planter. That was dads idea. I wanted to just get a 60' pull behind boom sprayer. But from dads perspective it's really easy for me to put the saddle tanks on and off every year. But I digress. Ever since we started that we have reduced our roundup to one spray typically in late June early July. Some fields have been clean enough that we didn't spray roundup at all but most have needed roundup once just to clean them up. I will say we have had some of the cleanest beans that I can remember since we started spraying with the planter and a lot of the neighbors have commented on it. Before that we would always spray roundup twice plus an application of residual after planting.
With regard to mares tale and water hemp. We have had some wet years that didn't get an early disking in and got grown up. We still run over it twice, just disk one day, then disk again the second day and plant the third. On those years are when we have the worst weed problems. Seems like if you knock them back early and keep them knocked down whether it be with chemicals or mechanical it's easier to control. Edited by wekracer - 12 Sep 2016 at 1:36pm |
Unless you want to spend 100 acre on spray, you don't no-till around here. I know a guy that tore a field up this year, had a good stand of beans, but couldn't kill the weeds. I have a neighbor, that works his ground starting early, and plants late, he has planted beans on beans for years, l mean like 20. His fields are usually clean. No one no tills around here, unless they farm to much, or live in town, and farm, but ain't a farmer, if you know what l mean. You can work ground way cheaper then spray, and l have my own rogator.
Jwmac7060 ![]() Orange Level ![]() ![]() Joined: 04 Jan 2014 Location: Indiana Points: 929 |
We also have our own rogator and work all of our ground...our marestail problem ended when we went back to plowing in the fall...when ever I double crop beans I either use liberty beans or burn down the wheat stubble with roundup and sharpen and that seems to hold the marestail
Sharpen is good on marestail, if you get there before it gets there
We actually went back to moldboarding our double crop bean stubble a few years ago just to get all of the ground turned completely over every couple of years. Since doing that our marestail problem has been pretty well nonexistent along with quite a few other troublesome weeds we had been having....the sees companys just keep adding genetics to all of this stuff thinking that is the be all to end all answer to weed control...it's kind of like that movie Jurassic Park....nature will eventually find a way...all of these weeds will become immune to all of these chemicals eventually...everybody better wake up and realize that.
Play Farmer ![]() Orange Level ![]() Joined: 13 Jan 2016 Location: NNY Points: 732 |
Agreed. We've always had super clean fields. This year started out that way but I think with our severe lack of rain the weeds were able to back up for a better start. Our corn looks great, our beans not-so-much. They'll be OK, they're just not the nicest, cleanest beans we're used to growing.
A little patch at the old home place was VT'd a day or 2 before beans were planted and may have been sprayed (glyphosate) a bit late. It's full of marestail.
The rest of the beans were sprayed commercially and seem to be OK. They probably got sprayed a little earlier. Anybody have a problem with wild cucumber in RR fields? I sprayed my food plots (beans) and had a bit left in the 4 wheeler tank so I sprayed (glyphosate and volunteer mix) along the south fence where cucumber had started. One plant acted like I put fertilizer on it till I went back and sprayed with 24D |
Dmpaul89 ![]() Orange Level ![]() ![]() Joined: 06 Mar 2013 Location: Edwardsville,IL Points: 1689 |
i may do liberty link next year. with the new seed retention program its a no-brainer. and liberty works. they are the cleanest fields around here. The new extend dicamba beans are a joke they will have a 120' set back required, and most weeds are on borders anyway
Edited by Dmpaul89 - 13 Sep 2016 at 8:05am |
I think my problem was at burndown, burnt but not dead, and it regrew. Around here you DON'T use gramoxone on marestail. It will kill the leaves but the stem is still alive and after you run over it with the drill it splits the stalk and it regrows. If I can find a decent 20-25ft disk with leveler I would try it on all fields this spring. Just can't do it with a 10ft over 400 acres. Now I don't have weed problems on my double crop land, the wheat stubble keeps them pretty clean.
VAfarmboy ![]() Silver Level ![]() Joined: 06 Dec 2013 Location: Virginia Points: 470 |
Not just the spray either those No-Till drills are not cheap. I am drilling beans with a Deere 450 Drill I paid $2000 for at an auction. The thing was like brand new but nobody wanted it because everyone has gone to No-Till and a 15' drill is too wide for deer plot guys. |
On the bold - you are correct, for the typical food plot guys. We do plots, my small tractor is a D17, I also have a Massey 1100 and a 7000 Allis. I have less in those 3 tractors than my brother paid for his new Ferris zero turn this year - and his is a gasser. We drill the beans with an 11' Deere FBB and plant our corn with a Deere 1240 4 row. We buy our stuff for pennies on the dollar because just the reason you said; it's too small for the typical real farmer and too big for the typical food plot guys. It's nothing but fun on a budget.
Adam Stratton ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: SW MO Points: 1363 |
What seed retention program are you talking about?
Great question. I knew a couple guys that had their own and it cost them a bundle. |
This new bean that mother Monsanto is coming with. You have to leave a 100 ft border around your field. You can't spray it with the spray, because of drift. You can't spray when there is 0 wind. Or over 12mph. Small window. And you have to clean your tank, 3 times, before going to something else. It isn't the answer !!!!! |
You have them figured out to !!!!! They make more money putting a "Trait" in something. And keep there patent on , so you have to buy there seed every year !!!! They don't give a $hit if it only last a few years, they will make something else up, to keep the money going in there pockets !!!! And the co-ops love it, because they get to sell everyone sees, every year !!!!! Edited by ILGLEANER - 13 Sep 2016 at 9:15pm |
actually the seed retention program is a stine thing. its for liberty beans. it just came out. you can plant stine beans next spring and use the seed to plant the next year. just have to pay the tech fees which i heard is around $18 a bag. add cleaning and treatment and your around $25 a bag. (half cost) you can even trade varieties with other farmers just cant sell them as seed of course.
Edited by Dmpaul89 - 13 Sep 2016 at 10:03pm |
You can save RR 1 beans for seed , clean them and keep them, and pay no one anything.
Funny how Monsanto had all there RR1 beans gone before the 2015 season, which you could have saved them from.
You got it bud...we cleaned everything up with using liberty for two years and plowing and working the ground the last couple of years....this year I'm cleaning my rr1 beans and replanting those bastartds next year....now if a guy could just find some affordable seed corn we might be able to make some money with these
I replanted my RR1 beans from last year with great results. My neighbor that farms 2500 acres said he will never replant anything because they will not yield but half. I don't see it myself. Even if they do yield half, you only have $9.00/bag in them instead of $50 or more. The only problem is wet springs with no treatment but you can buy it and apply yourself.
So, how much do you have to pay Monsanto ?
Page 12> |
