B Engine Cylinder Head Performance |
Post Reply | Page 12> |
Ryan59
Silver Level Joined: 30 May 2016 Location: Kansas Points: 68 |
Posted: 13 Jun 2016 at 5:02pm |
Hello gentlemen, ladies. First I would like to say that I am not pulling with my tractor, but I would like to share and ask questions about performance concerning just the model B (125ci) engine.
I removed the cylinder head off my engine, removed the valves and guides, pressure washed it and inspected it. There was substantial corrosion in the runners and valve pockets. I spent roughly six hours shaping and blending the runners and pocket areas to both remove the damage and smooth-blend below the valve seats and reduce the radii of the split intake "Y". Before doing a final smoothing/blending I took the head in to have .150 skimmed off the surface. Looking at the factory rocker arm assy I can see room for improvement. First I measured a stock rocker to get an idea of the ratio. Center of shaft to center of valve stem 1.95 and center of shaft to center of pushrod 1.30. Divide 1.95 by 1.30 equals 1.5 ratio. This was just an "eyeball" measurement but it's what I am going to go by. " border=""> |
Ryan59
Ryan59
Ryan59
Ryan59
Ryan59
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4471 |
The "tray" was used to keep oil away from the valve guides before stem seals were generally accepted.
If you're not looking for added performance for pulling, what is the need for the trick parts, porting and taking .150" off of the surface?
Many of these engines have run for many decades in factory form and most will out live many of use just as they were built.
Ryan59
Thanks Paul, I wasn't sure why that tray was used.
Shop finally called to say my cylinder head was finished. They media-blasted it first, installed the guides I supplied, installed hardened exhaust seats, cut the valve seat angles on a Serti machine. Lastly they milled the surface of the head .150. " border=""> Edited by Ryan59 - 23 Jun 2016 at 8:49pm |
CAL(KS)
Orange Level Joined: 18 Sep 2009 Location: Chapman, KS Points: 3774 |
Paul happens to be running a turbo CA
Ryan59
Ryan59
CAL(KS)
happen to have 2 kz 1000's sitting at dads place :)
Ryan59
Thanks(1)
Ryan59
I may retake these pictures with a different camera/lens. It's difficult to show the bowl porting. I spent a leisure 6 hours smoothing and blending the bowls to the runners. Not necessarily for performance because this engine has had water in it over a long periods of time. The piston domes of 1 and 2 are extremely bad and all of the sleeves will note hone out (pitting) Anyway I basically blended all the exhaust bowls and runners to match. I did a little at a time. After I removed so much on the 1st bad port, I would move to the next and so on until they were all equal (feeling with my calibrated index finger).
" border=""> Edited by Ryan59 - 23 Jun 2016 at 9:30pm |
Ryan59
CAL(KS)
my dad bought one new in 78 and still has it. bout 17k miles on it now. he got another one a couple of years ago so one of us boys could ride with him. its usually my brother who has no kids
Ryan59
Ryan59
Ryan59
One thing I did "open up" was the "Y" split area where the intake runners divide. I decided not to build-up the back-side wall of this split port with epoxy as described by a knowledgeable and highly respected person on this forum. I had to remind myself that I'm not going for the level of performance that his engine is built.
" border=""> Edited by Ryan59 - 23 Jun 2016 at 9:48pm |
Ryan59
Ryan59
I bought these 1.73, 7/16 stud Lunati's 19 years ago and would like to attempt to use them if at all possible. From the center of the push-rod to the center of the valve stem roller that are 1" shorter in length that the stock stamped steel & spot welded arms.
" border=""> Edited by Ryan59 - 24 Jun 2016 at 9:22pm |
Ryan59
patrickmull
Orange Level Joined: 11 Jan 2011 Location: Casey IL Points: 893 |
what is that distributor off of
Ryan59
With a blue cap? It's a Vertex magneto. It's off a Kawasaki KZ1000 drag bike.
Alex09(WI)
Orange Level Joined: 15 Mar 2012 Location: CECIL WI Points: 1699 |
Apparently this topic has become "look at my foreign motorbikes" instead of "B cylinder head performance"
www.awtractor.com
NEVER green
Orange Level Access Joined: 28 Feb 2013 Location: MN. Points: 6714 |
SO???!!! Performance is bilingual.
Ryan59
If you are thinking the pictures are taking up band width you are wrong.
They are simply linked to my photobucket account. They can go away as
quickly as they appeared.
As my cylinder head work progresses I will clear the motorcycle pics. Parts should have arrived Monday but YT said they are behind getting orders out. Head has been in the shop waiting..... This was my daily rider, 2010 FXDWG bought new. Had to sell when I retired. " border=""> |
Ryan59
That magneto would work on any 4-cylinder and V8 engines as well. Vertex makes a cap for dual-plug 4-cylinder heads. On a V8 the second wire would connect to a cylinder on the exhaust stroke. So 1-4-6-7 fire on the compression stroke and 8-3-5-2 fir on the exhaust stroke for that 720 degrees. Crank trigger ignitions use (or can use) 4 coils with dual plug wires coming out. As far as the crank trigger is concerned it's bolted to a 4-cylinder engine.
This is the kind of information that is universal. |
patrickmull
it looked like it could be used on my pulling tractor
Ryan59
And it would. If you had a front engine plate, it could mount on there backwards so the cap faces the engine & wires would be where they should be. The belt would be in front and be driven off the crank. The governor would still control the carburetor arm. Just put a block-off plate on the back side to keep oil in.
Looking at the mag off this tractor it doesn't have any advance/retard either so this wouldn't be any different. Set it at what? 20 degrees crankshaft? For stock governor. |
