FL430 Cornhead Parts
bharper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bharper Quote  Post ReplyReply Direct Link To This Post Topic: FL430 Cornhead Parts
    Posted: 04 Sep 2019 at 10:45pm
We picket a sample of corn today and the head wasn’t pulling the stalks down like it used too. I checked the blades and they looked ok but there is a shorter blade towards the rear of the roller. It is 9 inches long with 6 holes in it. I thought that was called the clip but the parts book “clip” isn’t the same as mine. Can someone tell me what that piece is actually called? Can these pieces cause the stalks not to pull through properly? We don’t have a local combine dealer anymore so I am having a hard time tracking this part down.   We may just weld metal strips along the edges of them. Thanks in advance.
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2019 at 6:37pm
are your deck plates adjusted properly? a thick stalked plant wont feed well if pinched.
www.agcopartsbooks.com is a good reference for parts diagrams, and check eBay for an operators manual.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
This page was generated in 0.147 seconds.
