Fixing belt pulley on 45
orangeman Ia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Ia Quote  Post ReplyReply Direct Link To This Post Topic: Fixing belt pulley on 45
    Posted: 10 Mar 2012 at 9:58am
What do I need to order for my belt pulley ? Leakingoil Thank you
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2012 at 10:19am
is it leaking out fron the inside shaft or where the the assembly goes into the frame and clutch housing?  im not sure but i think its just a rubber ring that seals the assembly to the housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Ia Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2012 at 10:32am
It"s leaking down on the rail of the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2012 at 11:51am
There is a cork seal that goes between the frame rail and the housing. If you clean that area out good, soak the new seal in oil, you can flex it enough to install without removing the frame rail.
