Finish Mower Gear Box Oil Change?
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Topic: Finish Mower Gear Box Oil Change?
    Posted: 03 May 2024 at 8:58am
The gear oil in the 6 foot Woods finish mower resembles something that comes out of the rear of the local Canada Geese.  LOL
I want to change it.  Only thought for now  is to pull the fill plug and hoist the mower up on it's side with the front loader.
Any suggestions on a better way?  Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2024 at 9:05am
i have used a Rose Gun.. basically looks like a grease gun without a grease tube.. Stick the hose into the fill port and pull back on the rod and it SUCKS the oil out.. Works good on oil or gear lube.. Not so good if it is THICK  or grease... If your seals dont leak and it still has gear lube ( instead of grease) this may work... If the fill is on the SIDE, then i have used a copper tube bent into a  sweeping 90 degree  to get into the hole.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2024 at 9:08am
Update - Fill lug is on the side and vent plug is on the top.  Good tip Steve.  Now I an going to price one of those sucker guns.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2024 at 9:10am
Auto Zone, WAl Mart, Farm Store...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2024 at 9:24am
Thanks Steve - got one ordered from Amazon
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2024 at 9:39pm
Used what was called Steam Cylinder Oil in all the industrial gearboxes I use to service or rebuild - Mobile 600 W steam cylinder oil
This page was generated in 0.375 seconds.
