Finger Mower question.
Message Reverse Sort Order
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Topic: Finger Mower question.
    Posted: 07 Feb 2011 at 5:10pm
Not sure about in the UK, but usually you can find pitman arms for sickle bar mowers already made here in US at tractor supply. Maybe you could try finding one at a store like that in the UK. Just be careful using it, the pitman arm is made to break if it becomes too stressed, meaning if you break it, you probably shouldn't be mowing the way your mowing (too steep, etc.).
joegrgraham View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joegrgraham Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2011 at 3:48pm
Thanks Ted, I was thinking along the lines of Oak as well.
If it seems like a good idea, do it. It's easier to apologise than to get permission.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2011 at 2:14pm
when I made pitman arms, I used oak, as it was readily available. Swath board I used maple as it was available.
Post Options Post Options   Thanks (0) Thanks(0)   Quote joegrgraham Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2011 at 1:49pm
Hi all, I think this may have been asked before, and I apologise if it has.
I've just started to restore a finger bar mower (an old Ford-Ransomes). What type of timber would anyone recommend using for the Pitman coupling and the swath board?
