Final drives pan gasket/RTV? |
CB-Man ![]() Bronze Level ![]() Joined: 22 Mar 2011 Location: Newport, MI Points: 41 |
![]() ![]() ![]() ![]() ![]() Posted: 25 Jun 2011 at 12:00pm |
When draining the final drives i think the manual says there is a cork gasket in there. Is it best to get a replacement gasket or just use RTV sealant?
GregLawlerMinn ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
I use new cork gaskets; readily available at your AGCO dealer (or Sandy Lake Implement/Dean Ag). Use a non hardning sealer (RTV) on the pan side then you are ready to change the fluid next time.
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
Jeff Z. NY ![]() Orange Level ![]() Joined: 11 Sep 2009 Points: 7326 |
Either or. They both work.
Your choice. If you use RTV put a good bead on so when the pan is bolted up it spreads even with no voids. |
wkpoor ![]() Orange Level ![]() Joined: 25 Apr 2010 Location: Amanda, OH Points: 825 |
Another RTV trick is to barely tighten the bolts with you fingers. Just enough to spread the sealant. Then the next day after it has cured do the final torque. That way you will be able to put pressure on the form in place gasket. If you torque up right away the seal will depend on adhesion only.
David Maddux ![]() Orange Level ![]() Joined: 13 Sep 2009 Points: 2535 |
I have started using the grey RTV and the instructions is to finger tight , then 1 hour later tighten. My problem is to comeback 1 hour later. My memory is not the best.
Don't worry about the hour, next day is better anyhow.
Thanks for the tips guys, I wanted to get this done this weekend and really didnt want to order a pan gasket. I will get some grey RTV and do what you mentioned.
Thanks alot
Brian
Gerald J. ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
In my VW manual where a lot came from the factory with RTV beaded in place they note a common detail. Always pass a bolt hole with the bead on the oil side of the surface, not outside the bolt, else the bolt will leak.
Gerald J. |
So that's why my neck is always wet.
The bolts in my neck are leaking. |
That is true. I worked as a mechanic in dealerships for 4-6 years. When ever I do differential covers I always lay the bead to the inside oil side then go back and make a full circle around the bolt.
Bill_MN ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1466 |
I used Permatex 81182 Gear Oil RTV sealant on the finals of my WD last summer, got it from NAPA. I would suggest going that route as it gives you a positive seal compared to dry cork, and as little as you change gear oil anyway it's not that big a deal to disassemble.
B26240 ![]() Orange Level ![]() Joined: 21 Nov 2009 Location: mn Points: 3860 |
I like the RTV system also, the cork wasn't that great to start with
Coke-in-MN ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Afton MN Points: 41921 |
Laying out the bead on the surface and then smooth it out well so there is a thin even film, then wait about 15 to 20 minutes for it to skin but not full cure , this has worked well for me .
Seems a lot of users run a bead like they are calking a window then tighten it up which makes a mess as the excess fallis into sealed area and migrates into fluid and bearings.
"Challenges are what make life interesting; overcoming them is what makes life meaningful." |
You have to use common sense on the size of the bead. If you spread it out too thin then when it is compressed sometimes it leaves a void.
This is also a good choice.
http://www.permatex.com/products/automotive/automotive_gasketing/gasket_makers/auto_permatex_ultra_black_maximum_oil_resistance_rtv_silicone_gasket_maker.htm |
http://www.amazon.com/Permatex-82180-Maximum-Resistance-Silicone/dp/tech-data/B0002UEN1U
Tripp ![]() Bronze Level ![]() ![]() Joined: 20 Jun 2011 Location: Florida Points: 45 |
Black RVT Silicone gaqsket maker.
