final drive breather caps
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Topic: final drive breather caps
    Posted: 04 Dec 2017 at 10:31am
Howdy friends.
A quick question regarding my HD16DC. I took the access plate off the back of the dozer where you can expose and clean the final drive and brake breather units.
On my tractor there is a 1/4" copper line with brass not nuts and a ferrel on each end connecting the left side breather to a valve cluster next to it. guessing its a steering valve. One on each side.
this line has a broken nut,.,,, I broke it, and wondering if this is just a passive breathing line or is it under any kind of pressure. Asking as I would rather replace with a flexible reinforced line of equal size. Will send pic later today.
Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2017 at 10:51am
My 7G has them directly on the brake actuator housings, may want to scan through the parts book at Minnpar to see what they show.
Thwas the rear of the donor, they sit one to either side off angle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2017 at 11:33am
Yup,,, mine too. Are they under pressure when tractor is in use? Just curious. In the manual they do not refer to them.
This page was generated in 0.215 seconds.
