Fiat allis loader won't start
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Topic: Fiat allis loader won't start
    Posted: 29 Aug 2020 at 2:30pm
I'm going to go look at a 1980 fiat allis bucket loader unsure of the size guy doesn't know much about it. Says it doesn't start said it ran good then went to start it and it wouldn't start. What should I look for for why its not starting? I'm going to check the filters and make sure that they are getting fuel. Maybe it's a faulty fuel shut off? Any tips for what to look for would be appreciated.
Roach View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roach Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2020 at 2:53pm
Need a little more info. What model is it? Does it turn over fast enough? If it does, check if enough fuel or any fuel is getting to the pump. I've had problems with fuel shut off switch but also plugged filters. Also had problems with the master switch under the seat.
I have a 1987 FL7.
1937 WC, 1948 G,1954 CA,1956 WD45, 1967 D17, 1937 M crawler, 1963 D-19, 1966 190XT, 1967 D-15, 1948 HG42 Cletrac, 1955 G456 Terra Trac, CAT 10 1928 and CAT 22 1938
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2020 at 3:23pm
I have to go look at it. Its got a 2 yard bucket guy doesn't know anything about it I didn't see any numbers on the side of the machine
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2020 at 6:39pm
Rubber tire or tracked?
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2020 at 6:44pm
Rubber tired
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2020 at 7:37pm
Also curious if it has a allis chalmers motor or perkins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roach Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2020 at 9:09pm
Always like to see pics if you can. Keep us up to date on things.
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2020 at 9:32pm
I would post a picture but my phone won't let me
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2020 at 9:42pm
[IMG
Edited by ac89 - 29 Aug 2020 at 10:11pm
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2020 at 9:43pm
Here she is. Guy wants 3500 for it. Thoughts? Pictures aren't great but it looks like it's in decent shape.
Edited by ac89 - 29 Aug 2020 at 10:12pm
Rusty Allis View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rusty Allis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2020 at 11:41pm
I never believe "ran when parked" stories. i'd hit him low if you can't hear it run.
also i'd be weary of going to get it running...price goes up then...unless you make an explicit deal with him...like if you get it running, it's still xxxx dollars, and you're still willing to buy it no matter what.
you may luck out, or you may have a boat anchor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2020 at 6:40am
As a Salvage or scrapper that is worth MAYBE a Grand, would offer no more as so many things can be wrong from sitting.  Brakes, Clutch, or power sift, hydraulics.  Bucket looks worse for wear, the owner added chains for slick tires(NOT Cheap if can find replacements) and as noted fuel system is down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2020 at 6:43am
Just guessing but appears a Early 545 series Allis not FA.  Roosa Master/Stanadyne pump on a Farm Tractor base series engine in it.
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2020 at 9:33am
That would be cool if it was a true allis chalmers. Thanks everyone for the advice I am going to go look at it and throw a battery in it and see if it turns over ok. Also going to check all fluids. I may offer him 1500 if it looks like it isn't a complete junk pile. Plus I have to figure trucking it's 45 minutes from me. I don't think it is going anywhere with the price he wants so I may make a fair offer if I like it.
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2020 at 9:36am
And yes I noticed that it has tire chains I know from experience loader tires aren't cheap so I will figure that into my offer
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2020 at 7:19pm
Now he's saying that he had it running 3 winters ago and it started running rough and he went to start it and the motor wouldn't turn over. So probably the motor is junk. So I'm thinking scrap price is the best I am going to do on it.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rusty Allis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2020 at 8:35pm
if you have to have it, sounds like a good plan. it could be as simple as a bad starter or as bad as a stuck engine.
wonder if it took a slug of water down the intake/exhaust
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2020 at 8:38pm
I'm going to bring a pipe wrench with me maybe I can get a bite of the crankshaft pulley to see if I can get it to turn. If I get it I probably will have motor rebuilt if it is rebuild able
JohnColo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnColo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2020 at 11:27pm
There are lots of 301 engines around, which might be a cheaper way to go then rebuilding it.  It looks just like mine, as far as the cab goes.  The problem mine has is the intake tube on the transmission is cracked and to replace or repair it entails pretty much dismantling the entire machine.  I can run it if I overfill the trans but then it gets hot and doesn't like to move very well.  Another one of those winter projects I may never get to.
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2020 at 8:07am
True the motors are fairly easy to come by. I may still buy it if I can figure out a way to get it on a trailer
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2020 at 9:40am
Where would the serial number be so I can see what year this beast is?
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2020 at 9:02pm
When I had my Fiat Allis FR12 which is basically identical to the 545, the no start issue I had was the fuel lift pump. That said, in this case, I think investigating before you invest is where wisdom begins.
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2020 at 10:25am
I plan on looking it over really good and think about how much I want to offer. I'm thinking scrap price will probably be my offer because I have a feeling it's going to need a motor. Plus who knows what else. Its just a hobby of mine to resurrect old allis iron. If I get it I will pick away at it little bit to a time
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2020 at 3:51pm
I looked at the loader turns out it's a 1966 allis chalmers 545d. It's in decent condition for what it is motor does turn. The engine oil was at proper level coolant was ok. He said he was running it and it started blowing black smoke and lost power. So I'm thinking it could possibly be the injector pump maybe even the turbo. We agreed on a price and I'll be getting it as soon as it's paid in full. I figure worse case scenario I can find a good running motor. Its going to be a good project anyhow I like bringing these old girls back to life.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2020 at 5:01pm
Black Stack on a diesel is lack of Air, turbo, air cleaner full of hornets nest, Mice are TERRIBLE for nests.
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2020 at 5:16pm
That's what I am hoping for something simple to fix
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2020 at 10:47pm
Your progress on this deal sounds good. This will make a great machine once you get it running!
Edited by Eric B - 05 Sep 2020 at 10:50pm
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2020 at 8:00am
Yes I think it will! I'm going to take my time on it and save up to fix it up so it will be a strong runner again. Does anyone know if I can still get brake cylinders for it? He said the brakes worked but leaked fluid really bad. He put all new lines on it.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2020 at 5:36pm
The way you put that, I take it regular hydraulic brakes. If master and wheel cylinders are to pitted to use,and new are not around you send them off and get them sleeved.
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2020 at 8:36am
Yes they're regular hydraulic brakes. Yeah I will have to figure out the best place to send them to.
