F3 question
Ben (MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Topic: F3 question
    Posted: 17 Aug 2025 at 3:24pm
The chaffer fingers on the F3 get bent in corn from cobs thrown by the chopper. I have the corn kit installed including the curtain and corrugated shield. Am I correct in that I am missing #40 on the parts diagram? If so, how does it attach if I can find one? What else should I be doing to correct this problem? Thank you!
Edited by Ben (MI) - 17 Aug 2025 at 3:25pm
Part time farming with a 1980 7060 and 1984 F3 hydro.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2025 at 4:58pm
Straw walkers need to be slid almost clear forward would be the first thing. The straw chopper has two pulleys on it and you need to be on the large one. The chopper cuttng fingers MUST be fully retracted for corn. There cannot be any opening to let the cobs get thrown forward.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2025 at 5:54pm
Shield has 8 bolts holding it in. Better have it if you want to save the rear wall. Corrugated shield needs to be in place adjusted correctly. Everything else Doc says. Can't remember if book speakes to all the placement/ adjustment of corn kit. With curtain in place i don't know how you're throwing cobs on chaffer. Maybe the missing shield.? The curtain just clears the knifes.
Edited by SteveM C/IL - 17 Aug 2025 at 5:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:19am
Thanks for the help guys. I do run the slower speed in corn with the knives fully retracted. How does moving the walkers forward help with protecting the chaffer? There's no info in the manual on the corn kit. I've not had any damage to the back wall. I will find a shield and adjust the walkers. Thanks again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:34am
For corn/beans the walkers should be 1 1/2" from the front, not way back like yours are.  With the walkers back that far, it looks like the gap under the walkers to the chopper front wall is more open, which isn't good. It also allows more cobs to cross over the chaffer/sieve area because they are too far back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:11am
Thank you!
Could the walker position also lead to shoe overloading? I have a problem with when I am getting too much return I have grain spillage where the shoe meets the frame.
Edited by Ben (MI) - Yesterday at 8:17am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:27am
YES !! Get the walkers almost clear forward to lighten the shoe load, especially in corn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:23am
Great info! Both of you have helped me a lot over the years. I truly appreciate it!
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 3:30pm
there were also pads that went under the ends and back of the straw walkers that had a lip on them to divert 'foul balls' down before they hit the shoe chaffer. Also by moving the  walkers  forward it will dump the cobs in the FRONT of the chopper and thus the cobs will be exited down and back - IF the cobs are dumped in the middle to back - the cobs will be thrown forward - again as a 'foul ball' would be hit in baseball. 71311820 best I can remember.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 3:36pm
If all else fails the MH3 combines had rubber flaps on the end of the walkers 71300960 - something like this could be mounted under the walker between the chopper chute and the shoe under each walker.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 4:27pm
Kind of hard to tell from the picture, but that doesn't look like an 1 5/8" round deep-tooth corn chaffer to me. That's a capacity negative for sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:56pm
Thanks guys, I will do some more checking and look into these suggestions. The chaffer is the adjustable one that came with the combine, I will look into what size it is. Great information as always, thanks again.
I just remembered that I have the walker plates new in a box. I didn't put them on since the walkers were not getting damaged. I didn't realize that the walker plates helped protect the chaffer from foul balls.
Edited by Ben (MI) - Yesterday at 7:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 34 minutes ago at 10:00am
I'm wondering if you need to speed up the clean grain elevator. If it can't keep up it will fill trough and spill back to return. Normally it just plugs the elevator. Does your F3 have clean grain drive on rt side driven off fan shaft? My F2 is different. Driven off double sprocket idler part of walker drive chain. It's been said that in their day 150 but corn was BIG yield. Takes some trickery to eat 200 bu corn at 3 1/2 mph. The corn chaffer with the first 6-8 rows on separate lever helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 47 minutes ago at 2:47pm
Steve, it is driven on the right side, for the life of me I can't remember from where. I've looked into the speed up kit for the clean grain, maybe consider it if the other changes you guys suggested don't help. 150 bushel corn is pretty good here on my marginal soil in tiny fields. Thank you very much for taking the time to help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 47 minutes ago at 5:47pm
An F-3 elevator is already sped up compared to an early F-2. The last F-2's are the same as this F-3.
