F/S WD/WD45 reconditioned parts |
Page 12> |
Rltool
Joined: 17 Jun 2013 Location: Middleville ,MI Points: 1833 |
Topic: F/S WD/WD45 reconditioned partsPosted: 28 Mar 2018 at 5:26pm |
I have some right brake & foot clutch pedals sleeved. $30 each with exchange for good usable old pedal. Or $45 without.
![]() New foot pedal shafts $25 ea. ![]() Upper steering bracket $30. I only have a couple of these ready right now. ![]() Long PTO shaft coupling sleeve $20ea. Have some machined undersized to accommodate worn short gearbox shafts. ![]() All prices do not include shipping. I will be going to the GOTO in Gray TN. So I can bring parts with me for free. Pm me or call if interested in any. (269) 8 zero 4-5984 New phone number. Thanks. Ray W. Edited by Rltool - 10 Oct 2020 at 8:54pm |
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3132 |
Posted: 29 Mar 2018 at 7:37am |
I like those pedals Ray. Mine are a little sloppy, but not too bad. If was still painting mine, I'd be calling you.
Rltool
Posted: 29 Mar 2018 at 4:38pm |
Thanks Dave. It does make it a whole lot nicer than them flopping around. I resize the foot clutch linkage hole back to original also.
Ray W. |
polarbear
Joined: 05 Jul 2016 Location: addieville il Points: 331 |
Posted: 04 Apr 2018 at 11:38am |
i am going to Gray Tn would meet you there would like a shaft and 2 set of peddles can bring some cores all six pieces 4 brake and 2 clutch
Rltool
Posted: 04 Apr 2018 at 7:14pm |
Can do Dennis.
I don’t sleeve the left brake pedals. Because they usually don’t get loose due to being clamped to the pedal shaft with the tapered bolt. I have some good used ones if yours are bad for what ever reason. Send me a pm with your phone number or give me a call so I can be sure I bring down all the parts you need. Thanks. Ray W. |
Unstyled
Posted: 06 Apr 2018 at 7:39am |
Do you sleeve/rebuild hand clutch levers?
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 06 Apr 2018 at 8:00am |
I think hand clutch levers are already sleeved. Can't remember for sure. Either that or I had mine sleeved on my WD 25 years ago.
Looked it up on AGCO parts and the early WD was not sleeved and stating at #34450 and up they were. |
Wink I am a Russian Bot |
Rltool
Posted: 06 Apr 2018 at 8:10am |
As Lonn said. For the hand clutches. All I’ve had to do is change out the bushings in them. I have the new bushings.
Didn’t know that about the earlier ones. Thanks for the info Lonn. Unstyled, if you need a later hand clutch lever that takes the bushings. I have a couple with new bushings in them. Edited by Rltool - 06 Apr 2018 at 8:14am |
Rltool
Posted: 17 Apr 2018 at 8:06am |
Will be leaving for TN next Wednesday.
I will be only bringing what parts people have spoken for before hand. As of right now. Thanks. Ray W. |
Tim NH
Joined: 16 Oct 2012 Location: Lancaster NH Points: 1154 |
Posted: 17 Apr 2018 at 4:02pm |
Probably your truck is near full w/ all the stuff your bringing for me. So do I dare check the pedal, and hand clutch on my 45. lol Tim
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18967 |
Posted: 17 Apr 2018 at 8:19pm |
Don't even bother checking Tim, just order new ones. You KNOW you'll need em.
Rltool
Posted: 17 Apr 2018 at 8:24pm |
My wife was just questioning if there was going to be room for her on our trip. LOL
Tick Tock Mr. Tim. Remember I’ll be transferring some of my truck load to your truck. Save shipping! Ray W. Good advice Ted J ! Edited by Rltool - 17 Apr 2018 at 8:27pm |
Tim NH
Posted: 18 Apr 2018 at 5:01am |
Good one Ray, lol. I'll get those parts in my truck for you.
Joe DeLisle
Posted: 21 Apr 2018 at 9:54pm |
Ray, I too would like to pick up some rebuilt pedals at the GOTO. Two clutch, and two right brake. I'll find you, but I can be found in the feature area, with the Buckeye Allis Club table. I'll bring core pedals. Thanks, Joe DeLisle
Rltool
Posted: 22 Apr 2018 at 11:37am |
Sounds good Joe. I’ll have them there for you. See you there.
Thanks! Ray W. |
Rltool
Posted: 03 Aug 2018 at 6:04am |
Will be going to the GOTO in Pontiac IL. Can bring any parts with me if anyone is interested.
Ray W. |
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8661 |
Posted: 03 Aug 2018 at 7:43am |
Nice work on these parts Ray. Yes most tractors need all these items. I tend to be too cheap and slobber them up.:)
Very tempting though, to just get good reconditioned items like you have! Regards, Chris
Rltool
Posted: 04 Aug 2018 at 11:37am |
Thank you for the compliment Chris! Your pretty handy in the shop. So this stuff would be no problem for you.
These parts are the result from having more than one, or 6 WD / WD45s. Ray W. |
Sugarmaker
Posted: 04 Aug 2018 at 9:55pm |
Ray, I am just ready to pull the rod for the brakes and clutch. I will see how bad its worn. Your new one looks real good. I like it when the tractor has these worn areas improved, and brought back. They just feel and function so much better! My one WD has the cross hatch worn off the pedals. You might want to sell these in sets so the wear marks match from pedal to pedal. Just another little detail!:) Regards, Chris
Rltool
Posted: 22 Aug 2018 at 7:56pm |
Btt before the show.
Ray W. |
Rltool
Posted: 09 Feb 2019 at 10:26am |
Putting this post back up for anyone needing any of these parts for winter projects.
I will be going to the GOTO in Union Grove & possibly the Orange Spectacular this summer. Ray W. |
Ted J
Posted: 09 Feb 2019 at 8:44pm |
Ray, bring with you 2 foot clutch pedals sleeved, 2 sleeves for the hand clutch.
Hope you can make both!! I will........grease gun and all. ![]() |
Ted J
Posted: 24 Feb 2019 at 1:20am |
Ray, I'm gonna bump this BTT for you.......
All I know is that Tim better have a pretty big truck!! What with all the stuff I am bringing him also! Ray, make that 4 sleeves for the hand clutch........IF I DON'T STOP buying tractors..... |
Rltool
Posted: 24 Feb 2019 at 6:31am |
Thanks Ted!
I got you covered for parts. Good job doing your part for the economy. ![]() Tim has parts at my place too. He may be trying to overload on parts so I have to drive back to NH to help haul.
Tim NH
Posted: 24 Feb 2019 at 7:46am |
Fella's I just realized I'm flying to Hutch, and that's before Union Grove. They have a massive parts area there. But I'm usually a few steps behind Ray. So I mostly get the small stuff. lol Tim
polarbear
Posted: 24 Feb 2019 at 11:31am |
bought his pieces GREAT WORK YOU WILL NOT BE SORRY ALSO A WONDERFUL PERSON
Ted J
Posted: 24 Feb 2019 at 9:10pm |
Tim, that is GREAT news! See you at Hutch also!!
Seeing as those steps won't fit into a suitcase, OR a carry on, I'll wait for Union Grove and bring em. Edited by Ted J - 24 Feb 2019 at 9:12pm |
Rltool
Posted: 25 Feb 2019 at 7:45pm |
Thank you for the compliment Dennis. Look forward to meeting up again & talking tractors.
Ray W. |
wiplowboy
Joined: 29 Nov 2012 Location: Custer Wisc. Points: 313 |
Posted: 25 Feb 2019 at 9:45pm |
Ray. Have your top link mount for D 17 packaged and ready to ship just need your address. Jim Seat bracket has Teds name on also.
Joe DeLisle
Posted: 13 Mar 2019 at 8:14pm |
You won't believe the difference the rebuilt pedals make! I advise replacing the shaft also if you replace the pedals. Finished my second set of pedals today, but this one did not include the pedal shaft. First set did, and it fit perfect, no more vivbrating of brake pedal on the fender, and no rubbibg of the clutch on the frame rail. Great improvement. And, Ray is great to work with!!
Page 12> |
