"F" gleaner shelling issue
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Topic: "F" gleaner shelling issue
    Posted: 03 Nov 2017 at 11:04am
This year our corn isn't drying down very well,still at 22.6 moisture. I was hoping to use both combines but the "F" apparently doesn't like higher moisture corn. It doesn't always completely shell the cob and some of the kernels left on the ear are ground up on the ends. Any tips to help with this. Ive tried lowering the cylinder till it breaks the cobs but even then it doesn't completely shell them. Dry corn 19 percent it works great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2017 at 11:36am
That is what filler bars on the cylinder are for......wet corn. How many concaves are installed  ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2017 at 12:00pm
I'd have to check but I believe 4. I thought it had filler bars but guess I'll have to check again. Haven't looked at it for 2 years. This combine doesn't see much use.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2017 at 12:54pm
Can you speed up the cylinder a little?
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2017 at 10:51pm
I gave that a try tonight and it worked. I figured it would grind it up more but it's shelling really nice now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2017 at 9:44am
Great!  22% is pretty normal here in the tundra, the corn isn't as brittle and susceptible to grinding and yet you need a little more oomph put into it to get it off the cob....I've never operated an F, but speed and cyl clearance work together in all makes and models pretty much the same way.  Glad you got going.
