Extra parts in engine kit |
Kraig (WI)
Joined: 19 Sep 2009 Location: Fairchild, WI Points: 163 |
Topic: Extra parts in engine kitPosted: 14 Feb 2010 at 9:49pm |
I'm over hauling my WD. In the gasket kit, there are two grey felt seals that I'm not sure where they go. I think they go in the Rear oil seal upper retainer and in the wide grove behind the rear oil seal in the rear main bearing cap. But there wasn't any seal in those places originally, just the felt seal in the narrow groves.
Also, the ring kit had the bent wire things. It looks like they go under the oil seal, but I tried putting them in and it won't work there. The rings go in nice without those pieces. I am reringing the original 4" pistons.
Kraig (WI)
<a href="http://s82.photobucket.com/albums/j264/ACKraig/?action=view¤t=ExtraParts.jpg" target="_blank"><img src="http://i82.photobucket.com/albums/j264/ACKraig/ExtraParts.jpg" border="0" alt="WD Extra Parts"></a>
7010,D17D,WD45,WD,WC,WC,B,
Gleaner K,60,66,72 |
Kraig (WI)
Posted: 14 Feb 2010 at 9:53pm |
Hmmm, why didn't my picture come in?
JoeM(GA)
Joined: 12 Sep 2009 Location: Cumming,GA Points: 4846 |
Posted: 14 Feb 2010 at 9:54pm |
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
everett048
Posted: 15 Feb 2010 at 1:37am |
I think i am right in this the two felt gaskets are for the oil pan? correct me if i am wrong,and the 4 rings go 1 in each piston in the bottom oil control ring the oil ring i believe is a multi peice and wont function correctly with out that part?.
hth Mark Everett |
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3937 |
Posted: 15 Feb 2010 at 9:50am |
You,re right, Mark. Those four "bent wire things" are part of the four piece oil control ring. They are a spring and go in the back of the ring groove to keep the ring seated against the cylinder wall. It won't seat properly without it.
Butch(OH)
Posted: 15 Feb 2010 at 10:38am |
The guys have the springs right. We used to call those "kickers" for oil rings. They go in first no matter what style oil rings you are using and yes they do make the rings compress harder, that is what they are supposed to do.
Richard Slaughter
Joined: 21 Oct 2009 Location: Columbus In. Points: 20 |
Posted: 15 Feb 2010 at 4:13pm |
Do you use old oil expanders if new set of rings do not have them, for a Ford 800 overhaul. There wer none in new ring set or any info in the instructions about usiing any expander devices.
Bruce Nelson
Joined: 17 Sep 2009 Location: Centuria, WI Points: 137 |
Posted: 15 Feb 2010 at 4:24pm |
If your ring set did not come with any. You don't need them.
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25317 |
Posted: 15 Feb 2010 at 5:37pm |
Shucks, I ALWAYS have parts left over. I thought that was normal!!!!!
mlpankey
Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
Posted: 15 Feb 2010 at 6:21pm |
Don(MO)
Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Posted: 15 Feb 2010 at 8:34pm |
Lou you and Mitch have me on the floor with that one. LMAO
Don
