Even mechanical lift
68mustang View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 68mustang Quote  Post ReplyReply Direct Link To This Post Topic: Even mechanical lift
    Posted: 03 Feb 2020 at 3:49pm
Picked up a mechanical lift for a 1939 wc , need information on taking it apart , shop manual only shows the break down.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2020 at 4:23pm
I would imagine you are talking about the "Power Lift" that mounts on top of the torque tube.  they were used for Cultivator lifts.  There was a plate you removed.  Connected to a worm drive in the drive train.  The later WC's had a throw out lever behind the plate so you did not have to be moving to lift the implement.  Some of our customers Jury Rigged them for side mounted mowers.  That was before the sophisticated hydraulics we have today.  Worked fine.
Don't recall to much on them.  In fact, I can never remember replacing or repairing one  At the time they were not that costly probably easier to replace then to repair.
Good Luck!
Bill Long
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2020 at 6:14pm
manual I have gives a little on disassembly-
Edited by JoeM(GA) - 03 Feb 2020 at 6:16pm
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote 68mustang Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2020 at 5:28am
Probably not worth trying to install these option to my WC.
Will probably need some parts after taking apart .
Thanks Joe
