Engine rebuild
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2023 at 9:47am
Charlie, were yours 4 inch bore ?? or I'm thinking they were 4 1/8" ??
cwsac.1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwsac.1 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2023 at 10:02am
Descriptions didn’t give compression ratio says high compression flat top pistons no Pin height given tried contacting vendor to ask questions waiting for a callback.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2023 at 11:38am
8.0 or 8.2 to 1 compression ratio will run on 87 octane gas, YES. Ignition timing should be retarded from 25 degrees BTDC down to 22 or 23 degrees BTDC as per an A-C bulletin 45 yrs ago.
The reason I asked was I have heard some of the guys saying that they were getting compression ratios of 12:1 with flat top pistons and some had to run aviation fuel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2023 at 11:57am
It's not because they are flat top pistons. It's because they are so tall they have 12 to 1 compression ratio. A flat top piston in an AC of a specific pin height is higher compression than a Power crater piston of the same exact height because there is no bowl.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwsac.1 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2023 at 12:09pm
You probably already know the pin height needed don’t you dr to get 8.2 to 1
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2023 at 6:23pm
some one buy buy some stuff and measure it so i do not buy somthing i do not want .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2023 at 7:14pm
For 4.125" bore pistons with flat tops, I calculate a piston pin height of 2.300" to 2.305" to come out at 8.2 to 1.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwsac.1 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2023 at 8:08pm
Cool very good thanks. Just curiosity how do you have all this crap memorized where you tractor, mechanics or something dr?
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2023 at 7:14am
If I were wanting to run a round baler, the best modification I'd do to my D17's engine, is to get a Two-Twenty with a cab and AC.
Why?
The D17 is a fantastic tractor for raking hay, and making square bales.  In my Grandfather's words, it was the 'finest hay-making tractor ever built'... and I agree, for the probably millions of square bales we put up...  and that was the mainstay production system, until the Hesston square-baler showed up.
Grandpa ran some round bales with the D17, but it wasn't the tractor's engine that was the greatest need, it was environmental comfort and safety.  Running the big roundie was absolutely impossible if the breeze came at you from any direction other than directly in your face.
I would not recommend an engine build investment on a D17 simply to run a round baler... I'd get a higher-power tractor with cab and AC... because there's a whole lot more to being effective and comfortable making round bales, than just compression ratio and fuel octane and PTO horsepower.
IF you have to build an engine's output up to make enough power for an agricultural load application, there's more significant problems waiting in the field that will stop your production when you're in the most operational peril.
Edited by DaveKamp - 29 Nov 2023 at 7:16am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2023 at 7:19am
He's been doing this a LOOOOOONG time...Wink
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2023 at 7:29am
He is not referred to as "Dr Allis" just to have a 'cool name' LOL
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwsac.1 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2023 at 7:34am
Yeah, I understand it’s not big enough for today’s standards, but I only got one horse to feed not going in the business of making hay Mostly fun and don’t want to deal with a little square bales
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2023 at 7:04am
The more economically sensible option, then, is to buy round bales... and either pay a little to have them delivered, or borrow a bale mover.
I'm neither an equestrian enthusiast nor a cattleman, but I've been just-entwined-enough in both to get the picture...  For just one horse, you'd get much better quality, and lower waste with hand fed squares.
The other option, if you REALLY want to bale, and particularly if you're looking for an outlet for historical enthusiasm, is to look for an Allis Roto-Baler.  It'll run nicely behind a WD-and-up.  They made a cool loader to pick 'em up, too.
Putting cubic money into an engine may bring up PTO horsepower, it doesn't address any other issues that a large round baler's operation includes.
Edited by DaveKamp - 30 Nov 2023 at 7:07am
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwsac.1 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2023 at 7:21am
Buying them is not as fun probably have to break down and get a bigger one after I’m done dealing with this one
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2023 at 7:45pm
dont know a bout a round baler but i grew up with a freind that baled round bales with a 3020 john deere  but the d17 running the new holland small square baler is the best hay baling combo ever made,  we custom baled in all conditions with a d17d when i was young
Post Options Post Options   Thanks (1) Thanks(1)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2023 at 11:35pm
That's exactly what my Grandfather used... I spent three long weeks each summer on the rack with my uncle, loading them from stern to stem, hitching 10 racks up in a train, to the 6x6, with four more in the field, he sent me to drive that train through the field, up the apron, across the road, and up the gravel hill, into the big field north of the dairy barn, then into a big circle, set the brakes, shut it down, leave it in low, and walk the two miles back down to help fill the last four.  My hands hurt just thinkin' about throwin' all those bales.  The 6x6 went mebbie a whole 4mph in 4th gear throttled to 1200rpm, and while it was a really uncomfortable noisy drive, it sure felt nice to spend 20 minutes off my feet while that beast growled up that grade.
Edited by DaveKamp - 30 Nov 2023 at 11:37pm
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2023 at 8:38am
Why?
  Even with a cab tractor while round baling I would turn out of the windrow to face the wind.   Takes more time, yep, could not stand all that dust and debris getting in every nook and cranny.
