Electrolysis Advice Needed |
KenBWisc
Joined: 15 Sep 2009 Location: Fall Creek, WI Points: 1186 |
Topic: Electrolysis Advice NeededPosted: 12 Apr 2018 at 10:37am |
I've been cooking out a very rusty engine block for over two weeks. It's still removing a significant amount of rust and corrosion We are leaving home for two weeks. Should I remove it from the electrolysis unit, wash it down and spray it with light oil or, leave it in the tub unplugged from the power source until I return?
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25255 |
Posted: 12 Apr 2018 at 10:38am |
I'd unplug the power supply, leave block in tank.
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8661 |
Posted: 12 Apr 2018 at 10:43am |
Well I haven't left it that long But I would go with the light oil option. Maybe better yet would be to just let it run while your gone? Especially if you have more clean time needed.
Maybe have some one check on it daily? I would be afraid it might rust some in the tub. But getting no air (submerged) maybe it would be OK? Are you getting it turned occasionally so that the line of site process is getting some of the internal areas? Regards, Chris
