Dual pump vs. Dual pump service
keppy32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote keppy32 Quote  Post ReplyReply Direct Link To This Post Topic: Dual pump vs. Dual pump service
    Posted: 03 Dec 2024 at 9:50am
On/in the 7040 parts book, what is the difference between these two items/entries? Dual Pump vs Dual Pump Service. Thank you
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2024 at 10:04am
To my mind, #246 would be a service replacement unit whereas #244 would be the factory fitted unit. Purely guessing mind & I'm sure folks who actually know will be ready to correct me, but makes sense in my small mind. (For example possibly a different drive coupler or slotted bolt holes allowing for installation without disturbing other parts).
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2024 at 10:20am
the gear pump shaft/gears are way different #'s
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2024 at 10:32am
Early trans pumps were 13 GPM and later were 17 GPM. Also other improvements all thru the gear pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote keppy32 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2024 at 10:55am
We are looking at rebuilding that pump in our 7040. serial is 70401775. If I try to find all the parts to recreate the seal kit for the pump under the dual pump part listing, I’m unable to find 7 pieces. If I look to find the parts under the dual pump service part listing, all seem to be available. Ultimately looking to see if it’s possible to rebuild our pump using the service pump kit/part listing.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2024 at 11:12am
 Does  anyone know the serial no cut off of the 7040??   Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2024 at 7:22pm
7040-5350 is where the newer pump was first used. Always remember unless you bought your tractor new, maybe it already has a newer pump installed sometime in the last 40+ years.
