Dropped washer while installing new brakes on CA
davefullmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davefullmer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 6:50pm
Maybe I am not seeing something.  Most machinery that i have worked on in factories,  have a spot in the casting where you can get to the inside of the groove and start prying.  Is one there that I don't see?  Because unless you can get behind that snap ring to pry against,  I don't see how it is possible to pry it out.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 7:13pm
9 out 10  of CA's when I take the hand clutch drum off they side right out .It's the other side that you just drill out a few holes on drum and pull it .
Post Options Post Options   Thanks (0) Thanks(0)   Quote davefullmer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 7:20pm
Fred,  are you and I talking about the same snap ring?  The one I am asking about fits in a groove between the bearing race and the seal on the inside end of the short pinion shaft.  The bearing supports the pinion shaft right next to the brake drum.  (right side of tractor) and is between the race and the seal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote davefullmer Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 6:19pm
Well,  I got the snap ring out,  but we sure twisted it getting it out.  I picked up new bearings and seals and a new woodruff  key but will have to go to Agco in the moring to get a new snap ring.
I am concerned about the shims that i am supposed to put on the end of the pinion shaft under the cover.  I suppose I just need to pick up shim stock and make what I need.
The housing has been cleaned up and if it doesn't rain tomorrow,  I am going to start putting it back together.  This is an outdoor project.  The snap ring was the hardest part to remove.  It wouldn't even move in the groove.  I frist tried some Gibbs penetrating and kept hitting the ends with a screw driver.  Finally,  I decided to use the torch and heat it up.  After it cooled some,  tapping started it to move.  Then we could move the race a little to give the snap ring some room to get a screwdriver under it.  When we got it out is was a spirial by about an inch.
Whew,  Ever notice that the darn engineers still haven't learned to make things easy to work on?.
pumpkinman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkinman Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 8:31pm
you dont have to take the snap ring out. it acts as stop so the seal dosent go in to far  and so for bearing cup. push the old cup out with a long pin punch  in stall new cup the same way  the bearing stas on the shaft. the seal gos in from the trans end of the housing the bearing cup from the wheel end dont cut seal with the woodruf key when putting shaft back in
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkinman Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 8:43pm
 you dont have to remove the snap ring .it acts as a stop for the seal and the bearing cup. take a long pin punch and push the old cup out tap the new cup in  from the wheel end of the housing, the seal from the trans end. dont cut the new seal with the woodruf key when putting shaft back in,
This page was generated in 0.116 seconds.
