doing some outside the box thinking
Message Reverse Sort Order
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Topic: doing some outside the box thinking
    Posted: 07 Feb 2011 at 8:45am
I am thinking half of a bbc 632 ci up to a  805 ci . for 316 to 402 cubic inches.
Tramway Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tramway Guy Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2011 at 7:38am
Later the Scouts had a 196 (half of a 392) V8.  The 152 had a Turbo option in mid-'60s; contemporary with the Corvair Spyder Turbo, and the Olds F85 Jetfire Turbo.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2011 at 6:22am
Originally posted by Brian Jasper co. Ia Brian Jasper co. Ia wrote:
IH built such a critter for use in the Scout. I've only seen one and it was rather odd looking. Half of a V-8. It used the same head I'm told. It somewhat resembled the Chrysler slant 6.
152cid, or the exact half of a 304 IH V8, Grandpa had a Scout 800 with the slat 4 in it. Ran good but lacked in the HP department quite a bit
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2011 at 8:08pm
I had an IH pickup truck with that slant 4 in it, 63 I believe.  Never seen another like it, wish I had it back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 9:01am
you can see one of these small blocks made into a four cylinder  over on midget madness guy from indy advertising one called he builds the eagle
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 8:47am
the scout engine was only 80 hp @4000 rpm if my memory served me.  my thinking is all the performance parts for a bbc would work for this .A stroker small block v8 0f 454 cubes would make a 227 four cylinder and with a 400 cfm head we doggies.
Edited by mlpankey - 05 Feb 2011 at 8:55am
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 1:06am
also have a gleaner "g" with a 292 chev on it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 1:05am
my gleaner "g" combine has a chev 350 on it
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 11:57pm
I had one of those slant 4's in a 63 Scout I bought in Ohio, just after I got out of the Army in 1970.  Had a snow plow, which I put in the back.  Took 4 days to drive to Colorado.  Just about everything passed me on I 70 but it was a fun drive.  Sure nice to see the Rockies after nearly two years.  Must have had a couple gallons of bondo in it.  Drove it with the top off all summer then sold it in the fall to a campground for snow removal.  Probably went to China long ago.
Allis Express participant
farmer0_1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer0_1 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 11:52pm
i saw two such scouts at the pnw ag show both had slant fours
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 11:49pm
I'll vouch for Brian's reference-  I had a '64 Scout 80 with a slant-four.  IH took off the driver's side bank (actually, they cast the block that way) and covered it with a stamped steel plate.  It was half of a 304, which made it a 152.  It was a rompin' stompin' machine... I could make zero-to-50 on a good day, but most days, it was tapped-out at 45mph.  It wasn't in the greatest state of tune, it was a right-hand drive (Ex-Postal-facto) and someone did a lousy job of spring-over-axle conversion, so it wasn't a good idea to go much past 45mph anyway.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 10:37pm
No BBC in AC's.350's in L's or M's or both?G's had 327's I think?(all Gleaners)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 6:38pm
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 6:14pm
Big block Chev was used in New Holland self propelled forage harvesters.  My neighbors had one, a 45 gallon drum was put on instead of the 25 gallon gas tank it came with as they needed all 45 gallons to go an afternoon of filling silo.  She sure sounded sweet when it was in the corn rows just starting to break out a field.  The exhaust would get glowing red and throw out a little flame.  If you were half a concession away you would swear there was a stock car track over where it was.  I think it was a 427 cu in
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 6:06pm
Heres what I am thinking 4.625 bore 5.3 stroke bbc with one side cut off of it to make a 356 cubic inch four cylinder topped with a 12 degree 540cfm profiler head roller cam and lifters of any bbc variety.  I think second gear in a WC and 10 grand on the tack would fly down the track.
Edited by mlpankey - 04 Feb 2011 at 6:40pm
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 5:25pm
Bill Baer did that a few years ago with a 460 or 560 in the NATPA with the IH V8 head on a tractor.  Ran good, but rules were changed real quick after
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 3:35pm
hmmm... if a truck has farm plates on it, is it 'agricultural' use ????
I know ,'splitting hairs'.......
heck if the NASCAR guys  can drill out carb mounting bolts.......
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 3:14pm
Heck if you want displacement, go get a CAT 3406, they are used in ag applications!  :-)  Just playin
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 2:46pm
I recently sold my pulling stuff .Has not been picked up yet schedule differences . I am sure it will be though. I was looking at the rules which say agriculture motor use.  This allows the 292 chevy out of a combine . V8 chevys were also used in combines but the rule states no v8s . So I ponder cutting one bank off a v8 and making a cross flow 4 cylinder like the one the midget sprint cars run . I know 327 and 350 chevys were used in combines did any use a bbc .  I could just get more cubes with the big block . Small block sb2 heads are capable of flowing 400 cfm but they are usually around 163 cubic inches and 350 horse at 8000rpms in midget 4 cylinder form. Big Block chevy heads are capable of 400 to 500 cfm out of the box. Do you guys think it would make a season before rule change?
Edited by mlpankey - 04 Feb 2011 at 2:50pm
