Does a D15 Crank pulley come ready for hyd. pump |
ChuckLuedtkeSEWI ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Jackson, WI Points: 1826 |
![]() ![]() ![]() ![]() ![]() Posted: 27 May 2010 at 6:22am |
Sold the loader off of my D15 complete with the hyd. pump that runs off of the crank pulley. Was wondering if the pulley that comes on a d15 has the bolt hole locations for the hyd. pump shaft already or is that something that had to be changed when putting a loader with live hyd. pump on? Just trying to find out for the new owner so that I know if we have to swap crankshaft pulleys or not. Thanks for any help.
FredW ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: N. Weston,OH Points: 588 |
The pulley is drilled and tapped for adapter to drive pump. Fred
I should also mention you can purchase a new adapter easier than remove yours and if you need a name for the company I have it somewhere. Fred
Thanks Fred. If you have that info, that would be great. I told the new owner it might be a good idea to put new rubber grommets by the hyd. pump as well as long as it is apart. Might be able to get them from the same place
