ditch witch v30 crowd lever?
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Topic: ditch witch v30 crowd lever?
    Posted: 27 Nov 2012 at 9:05pm
last winter we picked up a v30 for the farm. seems to work good haven't used it too much. there it a hyd lever labled "crowd" but it doesn't seem to do anything. does anyone know what this is for?
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2012 at 10:15pm
Hello Mr Goodwrench    Haven't worked on any trenchers in a very long time   Creep and crowd should be the same.  There should be a hyd flow control valve in that line that adjusts crowd speed, and the crowd lever to start and stop movement also it should reverse direction.   Good Luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2012 at 10:22pm
i assume you mean reverse the cutter ...i thought that but it must not work...guess i need a operators manual
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2012 at 9:55am
http://ditchwitchv30.informationconcerning.com/
