Discbine or Haybine |
Page <12 |
| Author | ||||
captaindana
Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2609 |
Posted: 20 Dec 2019 at 5:18am |
Wow Wekracer what a hay hog you have there! What model are you pulling there? We have to replace our 489 and 492 eventually and after seeing your short clip I’d think I had better lay off buying orange tractors and snow blowers and tillers and wagons and building pole sheds and balers and twin rake setups and focus on a discbine! 😳 What am I waiting for? Thanks! Dana
Blue Skies and Tail Winds
Dana |
| Sponsored Links | ||||
wekracer
Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1595 |
Posted: 20 Dec 2019 at 5:49am |
Captain I understand. So many toys, so little money. We have a 1431, 13’. It is an older flail model. We wanted rubber rolls which I think is a 1432 but we couldn’t pass up the deal we got on it.
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12418 |
Posted: 20 Dec 2019 at 7:17am |
This too.....I'm surprised a bit by the suggestion of putting a 185 on a discbine. Not that it won't do it, but I'd think you'd want a little more to take advantage of what one can do.
exSW
Joined: 21 Jul 2017 Location: Pennsylvania Points: 914 |
Posted: 20 Dec 2019 at 7:25am |
Discbines take more power. They're also harder on drivelines. I had a friends DX101 take the flexplate out of his 826 hydro twice before switching it to the 1066.
allisrutledge
Joined: 30 Mar 2010 Location: SurgoinsvilleTN Points: 1361 |
Posted: 20 Dec 2019 at 7:59am |
Ca at 20 hp with 6 ft cut---- 8050 at 140 hp÷ 20 Ca hp = 7x6ft =a 42 ft cut sickle. I think if they used the same power required equipment the 8050 would be more fuel efficient. Sure would get finished quicker. You got to compare the same mower. Yea I know that's crazy but how wide of cut discbine would a Ca pull ? 2ft- 3 ft? In good hay. Just thinkin Edited by allisrutledge - 20 Dec 2019 at 8:14am |
Tbone95
Posted: 20 Dec 2019 at 8:35am |
Hmm...well, since we're just thinking and it 6 months 'til hay makin' time.... I don't think of it that way at all, as in having to compare the same mower. In this case, we're talking acres mowed per investment in fuel. To me, that's the story, and the reason why I phrased that "question" the way that I did. That's just me. More than one way to think about it.
Brad in WA
Bronze Level Access
Joined: 29 Sep 2009 Location: Lynden,WA Points: 199 |
Posted: 20 Dec 2019 at 8:49am |
DanWi
Posted: 20 Dec 2019 at 11:03pm |
If you are getting the hay cut on time the 185 will do just fine with a 9ft discbine. The past couple of years because of all the rain we have had to finish 1st crop around the 1st of July to get dry hay and with the 190xt you could tell the mower was back there running in 6th gear.
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5469 |
Posted: 21 Dec 2019 at 7:32pm |
We continue to use our AC390 haybine. Recent upgrades were tiger teeth knives, bolts instead of rivets, and new guards. Cuts the thick orchard grass much better. We cut less than 30 acres each cutting. It has been a good machine but eventually it will need to be replaced. Ive run the NH discbine for my best friend a lot. It is a flail machine and is an absolute mowing machine. We will probably upgrade to a nice used one some day. Looked a really nice one this summer, but it was $14k!!! Ouch. Hard to justify with the limited acres we have.
Mikez
Posted: 22 Dec 2019 at 2:43pm |
When I first bought the discbine. Was hired to do some custom straw baleing. So I had done a 4 acre hay field of my own then went to the spring wheat, after about another 4 or 5 acres found an abandoned guide wire anchor and it took one of the gear boxes to one of the turtles. Luckily the power company paid for it. Other then that haven't had any issues with it. Ten or eleven years now.
Page <12 |
