Disc brakes
Acllss puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acllss puller Quote  Post ReplyReply Direct Link To This Post Topic: Disc brakes
    Posted: 04 Mar 2016 at 9:09pm
What are you guys using for a hubs to use as disc brakes on a190 rear end and how big of a diameter rotor can be used. Any ideas would be helpful thanks.I was thinking of machining the factory hub off then drilling it for whatever rotor we use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2016 at 9:37pm
That would be OK fine. Use the largest diameter you can for best results.
Larry W. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry W. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2016 at 9:54pm
I just saw a settup on a 190 today, they utilized crower clutch discs for the rotors , worked really well, and a very successful tractor.
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2016 at 9:46am
http://www.allischalmers.com/forum/forum_posts.asp?TID=67825&title=190-brakes
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acllss puller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2016 at 5:09pm
Brett did you post something or pics didn't come through
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2016 at 5:14pm
Just a link of a old thred " copy and paste" Not sure how to make it a "true" link
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2016 at 8:00pm
I asked about this that was the post from the past I used the  old inner hub as a pattern  and made an adapter to put ford Tauris rooters and calipers on used summit master cylinders they will lock the wheels up instantly the only draw back is I have no parking brake
Bob C IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2016 at 11:23am
if I could get pics to send off phone I'd send my homemade setup and works great!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2016 at 11:24am
I could text or email if someone wants to post em
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2016 at 11:29am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2016 at 11:37am
It let me do one pic only but it's Harley rotor and 4 piston caliper from a road glide and master cylinders from jegs
Edited by Bob C IL - 08 Mar 2016 at 11:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2016 at 9:15pm
if I do it again I'm going to use international rotors mounted to the back of my wheel hub hopefully I will have a better feel as the current set up has  induction factor
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2016 at 6:08am
You could put a microlock in to have a park brake, couldn't you?
AaronSEIA
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2016 at 8:09pm
I used rooters  from VW rabbit bolted to 190 disc splines. MACK
This page was generated in 0.213 seconds.
