Disc Brakes Allis 180 |
jrbynf
Joined: 01 Jun 2021 Location: Kansas City Points: 58 |
Topic: Disc Brakes Allis 180Posted: 18 hours 44 minutes ago at 12:48pm |
Been trying to engineer a disc brake setup for my 180. Basically removing current dry brakes, fabricating a rotor/hub that slides over the axle with a center the same as the spline of the axle, fabricating a caliper to retain the rotor bolted into the bearing retainer of ring and pinion gear. Thoughts?
Dirt Farmer
Silver Level Access
Posted: 16 hours 4 minutes ago at 3:28pm |
Just wondering why re-engineer something that has proven to work effectively for so many years
Posted: 15 hours 55 minutes ago at 3:37pm |
The caliper should be designed to drop in from the top rectangle hole and be secured with external bolts. Why?? so you can easily replace brake pads as they wear without pulling the final drive/axle back off. Calipers would have to be hydraulic applied. Then, what are you going to do for a brake lock ? trust a hydraulic master cylinder ?? Or is this a pulling tractor??
jrbynf
Posted: 15 hours 26 minutes ago at 4:06pm |
This is just a heavy use loader tractor. Tired of wearing out brakes doing heavy work. New brakes from A&I, shimmed perfectly to spec and still wear out with heavy usage. I also enjoy a good project
Posted: 13 hours 58 minutes ago at 5:34pm |
What is wearing out first?? the disc lining ?? Are you using the better quality/more expensive KEVLAR disc linings ?? I didn't think those could be worn out. As far as the shim clearance, I shoot for .020" to .025" which is tighter than A-C specs.
