Difference between Allis 400 and 500 loader |
WD45
Joined: 20 Sep 2009 Location: STAYNER,ONTARIO Points: 957 |
Topic: Difference between Allis 400 and 500 loaderPosted: 16 Nov 2016 at 7:54am |
Differences between a 400 loader and a 500 loader mounted on a D17.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Kcgrain
Joined: 24 Sep 2009 Location: Wisconsin Points: 795 |
Posted: 16 Nov 2016 at 9:13am |
A 500 had longer arms, and a bigger center support than the 400, other than that they are identical.
Posted: 16 Nov 2016 at 10:15am |
The towers are higher on the 500 loader over the 400....probably 3 to 4 inches taller. The 500 loader on a D-17 uses spacer blocks between the side frames, as the 500 fits 180-185-190-200 series which are wider than a D-17.
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10869 |
Posted: 16 Nov 2016 at 10:16am |
Pretty sure cylinders are a different length between the two also. Tracy
