Diesel or gas |
Post Reply |
Author | ||
D171958
Bronze Level Joined: 03 Aug 2024 Location: Iowa Points: 52 |
Posted: 19 hours 14 minutes ago at 8:40am |
Wondering if it would be better to put a 226 gas engine in a d17 or a 262 diesel.
Sponsored Links | ||
Orange Level Access Joined: 12 Sep 2009 Points: 20873 |
What chassis do you have now ?? If it is a GAS chassis, you must stay with a G-226 gas engine. If it is a DIESEL chassis you must stay with the D-262 diesel or G-262 gas engine family. The clutch shafts between the 226 and 262 families are different lengths. The side frames length are also 3 inches different and the hoods, etc.
Edited by DrAllis - 18 hours 57 minutes ago at 8:57am |
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 23112 |
Thanks(1)
OK, just HOW do you guys keep all this information in your heads ????
NEVER green
Orange Level Access Joined: 28 Feb 2013 Location: MN. Points: 7693 |
Mad genius's. Navel maneuvering
D171958
So to engine swap it it will be a big deal.
RedHeeler79
Bronze Level Joined: 09 Sep 2023 Location: NE Kansas Points: 122 |
Yep, lots of differences between the two. Even the lower steering shaft, and the fuel tank, radiator, throttle linkages, etc, etc…. Additionally, the 262 diesel has quite a few inherent problems that are costly and time consuming to fix, and parts availability is a real problem for them also.
Edited by RedHeeler79 - 10 hours 9 minutes ago at 5:45pm |
D171958, you have us all wondering if you even have an engine at all ??
Les Kerf
Orange Level Joined: 08 May 2020 Location: Idaho Points: 900 |
I too marvel at this! |
D171958
No I don’t have an engine for it seen it on Facebook it’s a gas series one I thought it would be pretty cool to put a Diesel engine in it if it was easy and cheap Thanks.
Easy? Nope. Cheap ? Not a chance !!
Post Reply | |
