diesel compression test adapters
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Topic: diesel compression test adapters
    Posted: 18 Jan 2010 at 4:46pm
Does anybody know if the injectors found in a 77/88, 770/880 Oliver are the same basic Bosch type found in the D17D? Seems like they are. The early 66/77/88 tractors used a PSB pump like the WD45D. Then they switched to the Stanadyne Roosa Master like A-C did. My diesel compression test set gives a part number and a picture of the adapter used to check White (Oliver) engines as far back as the 66/77/88. The picture of the adapter looks like it could. Has a bridge that looks like the 2 studs and nuts hold in place and a threaded part in the same basic shape as the Bosch injector.
Gary(OR) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(OR) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2010 at 3:17am
Dunno but one thing to keep in mind, D17Ds used different injectors from early to late models. The change happened somewhere in the vicinity of series II & III. I believe the same time they went from water pump on head to water pump on block.
Edited by Gary(OR) - 19 Jan 2010 at 3:19am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2010 at 8:00am
Gary, do you know what the difference is? Entirely different style injector, or just an internal change?
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2010 at 12:29pm
All those Lanova combustion chamber engines should use same compression adapter. while injectors will not interchange, the basic style is used in all I have seen. Case, MM, Oliver, Allis, MH. The adapters are usually slotted for the studs/bolts, so fit differing bolt spacings, then the whole assembly threads in or out of the "T" portion. hope this helps. Ed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2010 at 12:36pm
Ed, that sounds alot like what I see in the picture on the cover. I'll know tomorrow. Snap On guy stops on Wednesday.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(OR) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2010 at 5:42pm
They're basically the same but the most obvious difference is the tip portion that fits into the head.... early models are aprox 1/2 " dia while the later are around 3/8". Those numbers are ballpark. I've got some early injectors, if you can think of a way to adapt a gauge ?
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2010 at 5:57pm
I am in need of a diesel compression tester that  has fittings for 14mm plugs also. I busted two craftsmen 350 psi compression testers. Iam thinking this motor is going over 450 psi.
