Diamond tread front tires
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Topic: Diamond tread front tires
    Posted: 23 Oct 2010 at 2:16pm
 I am looking at putting some diamond tread tires on the front of my 7060 and wondered what size would work best. Ive been looking for 16.5x16.1's but didn't know if a 18.4x16.1 would work. thanks
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2010 at 10:00am
I'm not going to be much help, but a local tire shop should be able to set you in the right direction. I seen a 7060 on an auction a couple of years ago that had some huge diamond treads on the front, I'm not sure what size they were, but they were big to the point that the rims had to of not been factory to take a tire that size. I always have liked the diamond treads on the front of tractors, and have been thinking about putting them on my 190 XT. One memory I have as a kid, is a neighbor that had a 220 AC that was pretty hot, and had some 24.5-32's on the rear, and a good sized set of diamonds on the front. I didn't even like Allis at that time, but thought that tractor looked pretty awesome. Sorry for rambleing without giving any help, Darrel
doubledwrenching View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doubledwrenching Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2010 at 11:12am
sorry my new to tractors, but what is diamond tread
53 b
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2010 at 11:23am
http://www.tiretown.com/diamond.htm
Looks alot like turf tires. They were popular in the 70's and eightys for use on the front of large two wheel drive tractors, mostly because the larger ribbed tires were'nt as common yet and were more expensive.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2010 at 11:40am
be sure to size the tire proper too the size of the rim,trying to squeeze a wide tire on a too narrow of a rim will lead to early tire failure. a good tire shop will ask what width rim you have.
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2010 at 12:08pm
Diamond tread do not help the tractor turn very well.
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2010 at 2:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2010 at 2:56pm
my 7045 that i used to have with diamond thread
