diameter of 170 steering shaft
Steve A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A Quote  Post ReplyReply Direct Link To This Post Topic: diameter of 170 steering shaft
    Posted: 28 Feb 2020 at 5:03pm
Would anybody happen to know the diameter of the steering shaft-vertical shaft the steering wheel splines onto--just below the wheel? Dad's lifts up and disconnects from the orbital pump, and I'd like to make a collar to hold it down. Problem is it's 250 miles away to measure..
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2020 at 8:34pm
No experience on that model here but think something is wrong with current set up. Doubt it left factory being able to do what that one does. Something missing?
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2020 at 9:06pm
It sounds like you lost the snap ring on the shaft that locates it in the support tube.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2020 at 9:44pm
Pt # 70244457 ,one under wheel and one in the tube to keep it from pulling out...page 212 agcopartsbooks.com
