Deutz Allis disc mower
Message Reverse Sort Order
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Topic: Deutz Allis disc mower
    Posted: 12 Mar 2010 at 6:46pm
Does anyone have a source for manuals for one of these?
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2010 at 6:26pm
It is a Fahr unit -  shaft driven with modular spiral bevel pinion gear$ - Make sure the double stack bearings are tight in the inside and outside as the bar bed should be rock solid with no movement allowed. The outter hat should have no play. Keep the bed oil level up.  If the unit has any vibration it will self destruct in a few acres.  IT is getting to be a well experienced unit.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2010 at 4:30pm
I think back in the day they were OK.   We had a little bearing trouble in the bar which casued a vibration, other than that if it isnt worn out it'll cut just about anything.  Kinda hard on knives too. HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2010 at 3:39pm
I have a DA SM55 disc mower that I inherited. Does any one have any experience good or bad that they would want to share?
