Dang new ones are spendy
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Topic: Dang new ones are spendy
    Posted: 09 Jul 2013 at 4:28pm
Was looking at a new carb that is bigger for the wd after we go through this winter, looking at new ones they are way too much, I have heard of drilling the stock ones out, but how big of drill bit is needed for a 240 cubic inch motor with a cam reground for stock or slightly higher rims? Or is there a cheaper way to get a new one, I have a marvel schebler on hand but was told it was smaller ( by pank I think so yeah) is that correct. Also how do you know how big to drill the stock carb out? Ps I was looking for carbs at Tony's tractors and they were 400 dollars and will a d17 carb fit, I know a wd 45 will
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2013 at 4:56pm
The B- C carbs have a sleeve insert in the bore that can be removed and reamed oversize. I  worked on a WC carb that also had a sleeve... Does the WD- WD45 carb have that ? Boring 1/16 oversize and a bigger main jet will get more air and fuel to the cylinder, if you got the rest of the motor ready for that !
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2013 at 5:19pm
I have no clue if a wd and a wd 45 carb has that, the motor will be gone through this winter, just getting some parts lined up for it so I won't have to wait this winter
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2013 at 5:27pm
Call Steve @ B&B and he will fix you up.  Just tell him what your doing and you will be good.  He is an advertiser on here
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2013 at 5:41pm
That is what I was thinking just wondering what you guys came up with
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2013 at 6:44pm
We have used the carb from a 262 gasser. Some of them don't have an adjustable jet but you can get it in a rebuild kit. I think the carb on an XT is the same but has a bigger venture. It's a size bigger were the manifold and carb meet. Just match the hole or try to get to the same size. A 230 may have a bigger carb too.
