D-262 head bolt kit from ARP
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Topic: D-262 head bolt kit from ARP
    Posted: Yesterday at 7:07pm
I know someone on here in the past had part numbers or information on an ARP brand head bolt stud/nut kit for the D-262 diesel engine used in D-17 and D-19 tractors. Could someone help with this old information ?? Thanks for your help.
VaAllis1990 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VaAllis1990 Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:03pm
I bought mine through Mark Pfouts, he kept them in stock I think
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:56pm
I got mine right from ARP.
Think somewhere I have the part numbers…
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 23 hours 18 minutes ago at 9:00pm
Qty                      Part number                  Description
16                        AR6.500-1LB               STUD ½ X6.5 LONG BROACHED
2                          AR7.000-1LB               STUD 1/2X7.0 LONG BROACHED
2                          AR8.000-1LB               STUD 1/2X8.0 LONG BROACHED
20                        ARN34                          1/2X20 HEX NUT HEAD MAIN
20                        ARW78N                      ½ ID 7/8 OD H&M WASHER
Found them!!
If I remember right I had to cut like a 1/2” off the top of the studs under the rocker.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 hours 6 minutes ago at 9:12pm
Thank you !!! That's what we needed !!
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 30 minutes ago at 8:48am
thats execatant i still have to order a set for my series one engine    my series1 origanal block had studs when it tokk it apart and the series 2 engine block that i am having counter bored had bolts when i took it apart    is that the way they came new
