D21 help
D171958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D171958 Quote  Post ReplyReply Direct Link To This Post Topic: D21 help
    Posted: 11 Dec 2024 at 7:25pm
I was looking at a d21 and it’s a bareback with out a pto and I was wondering if you can put a pto shaft in without it costing a lot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2024 at 8:28pm
At a minimum, you'd need a lift arm housing which would contain the PTO clutch itself. Also need the handle and linkage from the platform on down to the lift arm housing. Then, there is the matter of whether there are the needed parts up front from the bell housing thru the 4-speed transmission. If the 4-speed tranny has a shift lever on the right side, going up to the brake pedal area, I'd say everything is in there. No shift lever it isn't. Think of how many hundreds of D-21 pullers that used to have all that stuff and removed it and by now thrown it all away.
Post Options Post Options   Thanks (0) Thanks(0)   Quote D171958 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2024 at 7:17am
So it could run into a big problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2024 at 7:21am
If the hollow PTO drive shaft isn't already inside the bellhousing and its lower connecting shaft thru the 4-speed tranny, it would be a very big deal. I have no idea if these front parts were standard equipment or not, regardless if it had a PTO clutch on the rear or didn't. As I said, if there is a shift lever on the right side of the 4-speed and it goes up to the brake pedal area, those parts must be inside.
Edited by DrAllis - 12 Dec 2024 at 7:22am
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2024 at 8:13am
If it left west allis without pto, the gears and shaft are not there, there is a special sleeve in the parts book to press onto the trans input shaft for models without pto, to take up the space that one with the pto live shaft would take up. The tractor in question could have had it removed for pulling reasons, but guessing it's a factory bareback he's wanting to put pto in. Better off finding a different one with it already in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote D171958 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2024 at 7:01am
Ok thanks for the help
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2024 at 11:12am
Not sure if your on Facebook, but here's a D21 that needs some TLC with a 3 point and PTO.
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote D171958 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2024 at 7:11am
That actually isn’t a bad deal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2024 at 8:02am
Have you looked to see if yours has the shift lever on the right side of the 4-speed tranny going up to the brake pedals???
Post Options Post Options   Thanks (0) Thanks(0)   Quote D171958 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2024 at 7:16am
No it didn’t have the shift lever
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2024 at 7:18am
So, it is completely empty inside from the pressure plate thru the whole driveline.
Post Options Post Options   Thanks (0) Thanks(0)   Quote D171958 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2024 at 7:27am
Ok thanks for the help have a merry christmas
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2024 at 6:04pm
I have a couple D21s for sale with pTO
phil
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2024 at 6:06pm
I have a couple d21s with pto for sale
phil
This page was generated in 0.039 seconds.
