D19 Water Pump Rebuild
PoppaBear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PoppaBear Quote  Post ReplyReply Direct Link To This Post Topic: D19 Water Pump Rebuild
    Posted: 06 Jan 2026 at 4:22pm
1963 Allis Chalmers D19, gasoline, wide front, survivor. #13101
New Member here... I'd like to rebuild my original Water Pump to keep the
original casting (#134445).  I have only found replacement pumps, but no rebuild kits.
Also, I'm not sure of the quality of replacement water pumps available.
Has anyone rebuilt one of these?  If so, what aftermaket bearings, seals,
gaskets, and impeller was used?  Any details would be appreciated like sizes & part numbers.
There is a different style between gas & diesel water pumps.  And also between Late
and Early Gas models, which is the length of the shaft (ie. Early Gas water pumps use
a longer shaft (4-15/16" length) versus the Late Gas (5") is my understanding)
I'm pretty handy, and have a friend that can assist with pressing out the shaft, etc.
I would like to get the aftermarket parts in advance to make the job easier.  In addition,
I am planning to replace the water tube, upper & lower radiator hoses, fan belts, etc.
Hopefully I can keep the radiator in place during this process.
Any other advice would be welcome.  Thank you in advance.
PoppaBear
Northern Illinois
1963 AC D-19 #13101
AC registry listed
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2026 at 8:11pm
Call Brenda at Sandy Lake Implement. She got me a kit sometime ago for a D15 Diesel waterpump that a customer sent to me to rebuild
  Or there are many places that will rebuild any waterpump you send them, Just get a Hemmings Motor News and look up "waterpump rebuilding"
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2026 at 9:55pm
Flying Dutch man does awesome work
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2026 at 7:36am
Do you have early or late model. Parts book says early has long filler neck on radiator     4-15/16”.
Later model have short
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2026 at 8:15am
Early or late model might not apply if engine has been replaced (combine engine)!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PoppaBear Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2026 at 11:02am
Update: About to remove the Water Pump.
Removed the radiator, and need advice on the Power Steering Pump bracket.
Looks like I need to remove the P/S pulley, then the pump, to get the bracket off....
Any advice would be greatly appreciated.
Note: This is an Early Gasoline 1963 D-19, S/N 13101.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PoppaBear Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2026 at 10:41am
UPDATE: Need to source a Water Tube, bypass for thermostat.
Doe's anyone have a source for this part?  1963 D-19 Gasoline Engine.
This tube is hard metal, with compression fittings on both ends.
Is it shown on page 67, of the D-19 Operators Manual, as Item #1 (shown in photo below).
Have a new Radiator, and rebuilt Water Pump ready to install.
WeisAC2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WeisAC2 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2026 at 3:35pm
Alex at A&W tractor was able to make one recently for my D15 diesel.  It fit perfectly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2026 at 9:26pm
You DO NOT want to remove the power steering pumps pulley !!!  They have a tendency to have that cheap lock nut get loose, and then the loose pulley destroys it and the shaft !! I always used a regular NF nut and red loctite it when rebuilding a pump (from the pulley getting loose) and tightening the nut tight. Have never once had a failure after using a real nut and loctite.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PoppaBear Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2026 at 8:43am
WeisAC2 - Thank you for the information.  I will contact him and let you know what happens.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PoppaBear Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2026 at 8:44am
DrAllis - Will Do!  Thank you for the heads up.  I will certainly follow your advice.
