D-19 Trans
MBolton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBolton Quote  Post ReplyReply Direct Link To This Post Topic: D-19 Trans
    Posted: 27 Nov 2010 at 9:17am
I read about it before and searched on the topic but came up empty both here and in my mind. What are the trans issues when my D-19 slips out of third gear when going down hill? It also has a low growl, seemingly ahead of the trans when idling out of gear. Are the two related?
Ken
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 11:50am
Seems like I've heard that if the jumping out of gear isn't real bad, the notches in the shift rails can be squared up and drilled a bit deeper. Growl could be the hyd pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBolton Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 7:08pm
bump
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 11:38pm
The gear jumping is common with all other AC tractors.  Quite likely you will find the input shaft has a lot of up and down movement (sloppy bearings).  This, combined with worn shift forks are the main reasons for jumping out of gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2010 at 8:59am
I think some might not agree with that statement. The ones that pop out of gear are usually the ones that have been abused and had minimal maintenance. There are a lot of early AC's that don't jump gears. CA's and 45's up through the 100 series probably had the most problems with this. JMO
NICKMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2010 at 9:03am
thank you correct police
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2010 at 9:05am
Yes, I should have mentioned that in the beginning - If they were abused and neglected.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2010 at 1:41pm
I still think engineering coulda done a better job though , there were  a bunch of tractors out there, I,m sure it was brought to there attention
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 11:50am
They fixed it with the 7000 series with what I think they called torque lock gears.
Wink
I am a Russian Bot
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 2:47pm
When your going down hill it changes the pressure on the gear causing it to pop out. Seen many many AC tractors that popped out of gear. Usually the one with the most wear. Could be in the top but my guess is its in the gears / collars . Fix can be pretty costly. Ive seen many gizmos for holding them in gear. bungee cords, locks, ect. Even saw one with a chain loop welded to the gear shift so it could be tied in.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2010 at 6:17pm
All good ways to destroy the shifting fork(s).
Wink
I am a Russian Bot
This page was generated in 0.049 seconds.
