D19 pistons
Model 70 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Topic: D19 pistons
    Posted: 07 Nov 2024 at 2:59pm
Looking for 1 or 2 good used or new D19 gas pistons if anyone out there has a couple. Thanks in advance
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2024 at 5:34pm
do you have a number off one can look thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2024 at 5:48pm
Sounds good I will see if I can find a number tonight,thank you
Edited by Model 70 - 07 Nov 2024 at 5:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2024 at 6:58pm
I think I may have a NOS piston/sleeve. I'll take a good look at it in the morning to see how it measures and what number is on the piston.
The piston is for a 3-9/16" bore and the sleeve is 8" tall. It has what I believe is a bowl for a gas engine.
Edited by PaulB - 07 Nov 2024 at 7:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2024 at 7:27pm
The number I came up with is 4512122. Sound right? Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2024 at 7:30pm
Sounds great. I just measured an old sleeve here and it is 8” tall and 3 9/16 bore
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2024 at 9:15am
The piston I have has the number 4513862. I don't know if the crosses over to your number or not. It definitely looks like a gas piston.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2024 at 10:57am
I will see if I can find out about that number and see if it crosses. Right now I’ve located parts but I’m always wanting more. Thank you
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2024 at 12:43am
Both gas pistons...4513862 replaces 4512122....HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2024 at 6:59am
That does help. Thank you
This page was generated in 0.234 seconds.
