D19 diesel rods
c linn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote c linn Quote  Post ReplyReply Direct Link To This Post Topic: D19 diesel rods
    Posted: 25 Jul 2010 at 8:19pm
Ihave 5 rods that have oil holes in the center of the rod and one that is not drilled for a oil hole
I  have 5 rods that are drilled in the center for oil passage and one that is not Do ineed to change this one out Thanks
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 4:55pm
Yes, the diesel rods are drilled.
Post Options Post Options   Thanks (0) Thanks(0)   Quote c linn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 10:31pm
The dealer must have used a gas rod instead of a diesel. do I need to change it
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2010 at 1:07pm
It will run the way it is, but its not right.   If you used it hard youll get more wear on the wrist pin with the non drilled rod.  Id find another rifle drilled rod.   HTH
