D17-III Transmission Lubricant
JWingerter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JWingerter Quote  Post ReplyReply Direct Link To This Post Topic: D17-III Transmission Lubricant
    Posted: 15 Jun 2016 at 9:35am
It's the large, round cap with a dipstick and it's just forward of the seat.  Looks quite dark.  Who knows when it was last changed?
Where do I drain and what would be a good choice for the replacement fluid?
D17 Series III
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2016 at 12:03pm
821 or equivalent trans hydraulic oil or you could use 80-90 gear lube in that application since it's not a hydraulic reservoir. Large plug under transmission to drain. Can't remember if just one plug or not but I think it's just one in a D17.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2016 at 12:14pm
I would use the Universal transdraulic fluid. If the old stuff is thick and not too clean, it might not hurt to spray around thru the fill hole with some diesel and drain it again.
This page was generated in 0.106 seconds.
