D17D Piston and rings
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Topic: D17D Piston and rings
    Posted: 22 Apr 2010 at 12:20am
My D17D got a valve stuck open and it was hitting the piston. Should have space open in the shop this weekend and will roll it in and pull the head and take it to the engine shop for rebuilding. I am expecting to see the piston damaged/cracked as a result of the stuck valve and am wondering if one can purchase a single piston/ring/wrist pin set?
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2010 at 7:17am
Yes, you can. I just puchased one sleeve and piston assembly this past winter. I think it was around $110
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2010 at 8:53pm
I guess I should have asked for a source on where to purchase a Piston/ring/wrist pin assembly. Any suggestions?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2010 at 9:25pm
I believe it was "Daves Ag service" in Humbolt IA Not positive though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2010 at 9:33pm
I got a set of sleeves and pistons from Sandy Lake. $145 per hole for USA made aftermarket. A little over $200 per hole for AGCO parts.
