D17D Clutch?
Gordy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gordy Quote  Post ReplyReply Direct Link To This Post Topic: D17D Clutch?
    Posted: 28 Jan 2012 at 9:20am
Just installed engine in my latest project D17D, Clutch pedal has several inches of
freeplay with adjustment all the way out and release fingers set at 2-7/16" as book says
have new throwout bearing and clutch plate that appears to be correct thickness. clutch does release OK just seems to have too much freeplay on the pedal before it begins to release. I remember having same thing on a D15 but don't think I ever found why.
Is this normal for these D series.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2012 at 9:26am
As the clutch plate, flywheel, and pressure plate wear the freeplay will decrease.  As long as the clutch releases, is adjusted correctly and isnt uncomfortable to use I wouldnt  worry about it, sounds like everythng is right.  HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gordy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2012 at 10:00am
WOW! Thanks for the quick response
JOHN N/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JOHN N/IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2012 at 6:15pm
Gordy just curious what did you all have to do on your 17d .I have a 58 17d that we went through came out pretty good we really like this tractor .Ours has the narrow front and is all around a nice tractor.Good luke with yours,John
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gordy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2012 at 8:04pm
John. I got this tractor with a stuck engine have rebuilt engine. bearings, sleeves, pistons, rebuilt injectors and pump head had been done, all new tires.kind of a long expensive project but hope to have it done this year with new paint should be a nice tractor.
