D175 Main Bearing options
Message Reverse Sort Order
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Topic: D175 Main Bearing options
    Posted: 05 Jun 2025 at 7:51am
I have a few 4 cylinder Buda diesel cranks that have not been inspected...
I'll mic them and get back with you....
Edited by Macon Rounds - 05 Jun 2025 at 8:11am
Heathg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathg Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2025 at 7:41am
I have found bearings, but I will not be able to catch a rod journal on my crank at 0.040 undersize.
I am now looking for a crankshaft with casting number 4512316 or 74512316 for the D175 engine that can be cleaned up at 0.040 undersize or less.
Any help would be greatly appreciated
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathg Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2025 at 8:12am
Thankyou
Pfouts Family Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pfouts Family Farm Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2025 at 11:09am
Have sets of .040 main bearings in stock.  Give me a call 330-569-7037
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2025 at 7:52pm
Originally posted by Heathg Heathg wrote:
... I have been working on this project for a number of years with road blocks all along the way. I appreciate any help or ideas.
What I know about your engine would fit on the head of a pin with room left over for the Declaration of Independence, but I do know that in the motorsports world that folks will often use rods, etc. from other brands of engines and have them modified to fit.
If your pockets are deep enough, custom rods can be had (it sure is easy to spend other peoples money) Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2025 at 7:31pm
I'm all for welding a crank for pulling, but never for use in a farm/work application. Diesel cranks are generally harder journals than gasoline engine cranks. Find a different crank or engine.
Edited by DrAllis - 02 Jun 2025 at 7:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2025 at 6:58pm
I have had many cranks stroked where 4 or more journals were welded on without issues. Find another crank company.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathg Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2025 at 4:49pm
Thank you, I had considered that but what I have heard is they only want to weld on one journal and not on all five die to heat fracturing. If you have any other ideas or people who I might talk with that would be helpful. I have been working on this project for a number of years with road blocks all along the way. I appreciate any help or ideas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2025 at 3:10pm
Considering how hard parts are to find for those BUDA engines, you might be better to send your crank to one of the places that strokes cranks and have it built up to STD bearings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathg Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2025 at 12:00pm
Rebuilding my Allis Chalmers HD3 Crawler with a D175 motor. Trying to source main bearings for a 0.040 ground journal. Or if anyone knows where to source a crankshaft. Any info would be greatly appreciated.
