D17 tranny fluid |
truckerfarmer
Joined: 26 Jan 2013 Location: Watertown, SD Points: 3292 |
Topic: D17 tranny fluidPosted: 15 Nov 2023 at 6:31am |
Got the new shifter boot on last night. Now I want to change the fluid. Can I use hy/tran, or does anyone recommend something different?
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
Clay
Joined: 11 Sep 2009 Location: Udall, Kansas Points: 10047 |
Posted: 15 Nov 2023 at 7:54am |
As long as it meets the 821 spec, you should be ok.
truckerfarmer
Posted: 16 Nov 2023 at 6:25am |
Thanks Clay. The 821 spec is what I was needing. Knew there was something special, just couldn't remember what it was.
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3074 |
Posted: 16 Nov 2023 at 6:39am |
I use Deere Hy-Tran in my D17. Almost any modern hydraulic fluid will meet and exceed the original D17 oil spec and quality.
