D17 tractor
somebody View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote somebody Quote  Post ReplyReply Direct Link To This Post Topic: D17 tractor
    Posted: 08 Sep 2010 at 7:41am
226 4 cylinder gas engine
could someone tell me if this is the correct valve arrangement?
 starting at front of head     E  I   I  E   E  I   I  E
Also if anyone need them I ended up with a set of .020 rod bearings and a set of .030 main bearings new still in box.
Many thanks
paulinkansas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulinkansas Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 9:10am
Old McDonald had a farm, E I E I....
But seriously, your valve arrangement looks correct.  The exhaust valves are a little bigger than the intake valves.
CJohnS MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 10:03am
BobH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobH Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 10:07am
If your settin valve lash,I set mine all at .012.
Post Options Post Options   Thanks (0) Thanks(0)   Quote somebody Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 10:58am
I am setting the valve lash and they are a little loud and I just wanted to be sure if I was doing it right, I have worked diesels for years and the valves adjust a lot different from an allis chalmers gas.
I do appreciate your info.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 6:34pm
If you ever have the occasion to remove your intake/exhaust manifold, you will see why your configuration is correct.
There are 4 exhaust ports, one at each end and two in the middle.
There are only 2 intake ports as 1 and 2  cylinders are "siamesed" into a common port and 3 and 4 cylinders into a second port.
Not the ideal setup for a high performance racing engine but works fine on a tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 6:36pm
On second thought, I guess it will be fairly obvious if you look at the manifold configuration as its mounted on the engine.
This page was generated in 0.143 seconds.
