d-17 throttle conversion |
ORANGE JUICE
Joined: 07 Feb 2011 Location: BowlingGreen,KY Points: 35 |
Topic: d-17 throttle conversionPosted: 24 Mar 2012 at 5:00pm |
I need the solution to convert my power unit motor to tractor. I got a little ahead of myself and mounted the motor and front end so I need a bushing and a seal for the lever going in to the front cover. I hope this can be done with the front cover still on the tractor. Any help will be appreciated greatly.
Orange Blood
Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Posted: 25 Mar 2012 at 7:42am |
Hey Orange Juice,
Well, you probably can, if the distributor or Power steering drive is removed, and the front governor cover is also off, however you run a high chance of loosing parts down inside the engine. I would stuff old T-shirt rags in ever nook and cranny around the cam gear, front and back, the reason I say T-Shirt rags, is because they will stay together when you go to pull them out, paper towels may soak oil, and come apart or tear when you go to pull them out, and then you have more work to do. Anyway, you have to remove the governor bearing fork from the end of the shaft before removing the rod out the other side.
Still in use:
ORANGE JUICE
Posted: 25 Mar 2012 at 1:34pm |
Anybody know the seak number
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5899 |
Posted: 25 Mar 2012 at 4:32pm |
Is that the same as Seik Number - 911
Gary
ORANGE JUICE
Posted: 01 Apr 2012 at 2:27pm |
Looks like the seal (not seak) number is 51x14. I cant make out the manufacturer. |
norm[ind]
Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
Posted: 01 Apr 2012 at 2:47pm |
we have the seal and bushing in stock 1-574-342-4545
